napasteve |
914 driving winemaker ![]() ![]() ![]() Group: Members Posts: 511 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California ![]() ![]() |
How do you avoid kinking the fuel lines below the gas tank?
Now that I'm installing a new fuel pump, I thought it might be a good idea to be sure that the new SS fuel lines were not obstructed. So I poured a gallon of gas into the tank to confirm gas flow back to below the engine. No gas came out. I then put in about 5 gallons of gas and visually confirmed that the fuel was completely covering the sock. Still no flow. Ugh. In retrospect, my old fuel pump may have been OK; it was just starved for fuel. (That's OK as a new fuel pump is probably a good idea anyway.) So out with the fuel tank again. As I pulled the tank, I could see that the larger line was kinked. With the tank out, I blew air thru the lines; no obstruction. So what is the secret? Is there a standard length of hose between the tank and the SS lines? Once the tank is back in place, it's really hard to examine the hoses. FYI I'm using the 5/16 and 3/8 fuel lines that Tangerine supplied (Gates Barricade MPI Fuel Injection hose). Any advise is appreciated. |
Lo-Fi Version | Time is now: 16th July 2025 - 03:46 AM |
