| 914_teener |
Apr 17 2016, 11:15 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Yes.
| porschetub |
Apr 17 2016, 02:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,091 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
yes make the other end of the fuel hose (tank side) on a loop hose position. And check while lowering the tank, the fuel hose will make the loop by itself. Did it 3x on 3 different cars and I all went well. (IMG:style_emoticons/default/agree.gif) ,did mine the same way,position the tank fitting @ the right angle and it not an issue,good quality hose appears to kink less also as it has more reinforcing. |
Lo-Fi Version | Time is now: 2nd May 2026 - 04:23 AM |
