Oil light comes on but there's pressure |
PanelBilly |
Apr 15 2016, 08:48 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
boxsterfan |
Apr 15 2016, 09:19 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
What weight of oil you running?
What's your oil temp (estimated) when you are warmed up? 10psi is a bit low I believe, but others will chime in. This thread says 10psi at idle is OK, but if it kept tripping my idiot light, I'd be nervous also. http://www.914world.com/bbs2/index.php?showtopic=106259 |
PancakePorsche |
Apr 16 2016, 12:34 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
10 Lbs is to low. Kinda a common problem on some engines without the highly recommended crankcase oil modification. I get 20-25 hot idle on my 2.7 after the mod.
Without the mod oil pressure relief valve dumps heated oil right back into the pick up side of oil pump causing crankcase oil temps to run high and subsequent low pressure especially on a hot day. The modification was permanently adopted on the 3.0 and later engines. |
rgalla9146 |
Apr 16 2016, 01:50 AM
Advanced Member Group: Members Posts: 4,555 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
All older 6 cylinder engines usually saw the OP light on at hot idle.
porschetub |
Apr 16 2016, 01:51 AM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
10 Lbs is to low. Kinda a common problem on some engines without the highly recommended crankcase oil modification. I get 20-25 hot idle on my 2.7 after the mod. Without the mod oil pressure relief valve dumps heated oil right back into the pick up side of oil pump causing crankcase oil temps to run high and subsequent low pressure especially on a hot day. The modification was permanently adopted on the 3.0 and later engines. I was led to believe on a six 10psi/1000rpm is normal ,however don't know what the normal pressure at idle is,you have stated that pressure....I have done the oil line restrictor mod as per Waynes book is that what you refer to ? I believe you are maybe talking about something else?,please tell more. boxterfan you jumped the gun on this one and provided info for a 4cyl engine,billys motor is a six. |
PanelBilly |
Apr 16 2016, 09:49 AM
It a 79 3.0.
porschetub |
Apr 17 2016, 12:38 AM
It a 79 3.0. My thinking is that 10psi will still be ok but do you have an increase when u blip the throttle to say 1500 rpm,a quick response in pressure would indicate a good oil pump surely (IMG:style_emoticons/default/confused24.gif) |
sixnotfour |
Apr 17 2016, 05:22 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
that sender grounds at about 6 psi....buy a new one they are cheep...
I would cut the filter open and look for excessive deposits,,,new motor you want to be sure all is OK |
PanelBilly |
Apr 17 2016, 08:36 AM
Talked with the guy who built the engine and he said the break in oil has something to do with this too. He wasn't concerned since it jumps right up with rpm
sixnotfour |
Apr 17 2016, 10:51 AM
your still running break in oil ?? you should change it ...
Lo-Fi Version | Time is now: 19th May 2024 - 07:49 AM |
