Uhh-Ohh…., My Ongoing 914 Build Adventures.... |
Larmo63 |
Apr 16 2016, 07:09 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I think a main bearing took a shit. Dammit.
Catorse |
Oct 5 2016, 10:55 AM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
No heat required, they just spin right out with the right collet tool. You would NOT replace these with bolts, use bolts only for affixing the case to the yoke, then toss them and put the studs back.
Studs are ALWAYS stronger than bolts in this application which is why Porsche made it like that. |
mb911 |
Oct 5 2016, 12:17 PM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
No heat required, they just spin right out with the right collet tool. You would NOT replace these with bolts, use bolts only for affixing the case to the yoke, then toss them and put the studs back. Studs are ALWAYS stronger than bolts in this application which is why Porsche made it like that. And the fact that bolts are meant to be removed thus potential for stripping threads etc. For some reason when I got this engine it didn't have studs.. I would like studs but I am using a factory engine mount so I need to search for the correct length. You can use some heat if needed though it wont hurt anything.. I weld mangnesium at least once a week as I have a pile of fans and housings I am repairing for people.. It can be done safely |
Lo-Fi Version | Time is now: 26th April 2024 - 05:11 AM |
