Uhh-Ohh…., My Ongoing 914 Build Adventures.... |
Catorse |
Oct 25 2016, 02:22 PM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
By all means try and find a cap nut that will work - post a link, let us know what you find. Saves me lathe time.
euro911 |
Oct 25 2016, 03:07 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Hoping someone already has a tank out so they can measure the bung and post the size for us (IMG:style_emoticons/default/popcorn[1].gif)
Larmo63 |
Oct 25 2016, 10:43 PM
It's actually a fine little piece of art.
Larmo63 |
Oct 29 2016, 09:33 PM
Larmo63 |
Oct 29 2016, 09:34 PM
Larmo63 |
Oct 29 2016, 09:37 PM
AN -12 lines fit through the stock hole openings in the triangle gussets along the longitudinal. Yay.
I'm trying to simplify this. |
Larmo63 |
Oct 29 2016, 09:43 PM
I did a simple GT mod by installing the hood opener on the grille.
Some people may not like it but I do. Attached thumbnail(s) |
barefoot |
Oct 30 2016, 05:00 AM
Senior Member Group: Members Posts: 1,271 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I drained all remaining gas out of the car, pulled the tank and had my handy-dandy machinist friend make this custom aluminum tank plug for the return line inlet in the tank that I will not be using. It is made to be press fit, and with a bit of gas Permatex, it should do the trick. You inspired me, my return fitting was in poorer condition than yours, so I made an aluminum plug similar to yours, here's the dimensions: 3 diameters, top one that goes into the tank fitting is .45"dia by 0.3" long mid part that fits into nut is .66" dia by .1 long, and bottom one that protrudes out bottom of nut is .37" dia by 0.3 long. I use Viton O-ring size 2-015 is's an .070 section ring with ID of about.48" |
76-914 |
Oct 30 2016, 08:34 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
A few things are happening, I finally took a look at the driver's side long and this is what I found. Looks solid! Damn, one would think that might be 1st on your list. Oh well, your a lucky man and good on ya. (IMG:style_emoticons/default/poke.gif) Now get back to work so you can make Rt 66 in your 914. (IMG:style_emoticons/default/beerchug.gif) Kent |
gereed75 |
Oct 30 2016, 08:45 AM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I drained all remaining gas out of the car, pulled the tank and had my handy-dandy machinist friend make this custom aluminum tank plug for the return line inlet in the tank that I will not be using. It is made to be press fit, and with a bit of gas Permatex, it should do the trick. You inspired me, my return fitting was in poorer condition than yours, so I made an aluminum plug similar to yours, here's the dimensions: 3 diameters, top one that goes into the tank fitting is .45"dia by 0.3" long mid part that fits into nut is .66" dia by .1 long, and bottom one that protrudes out bottom of nut is .37" dia by 0.3 long. I use Viton O-ring size 2-015 is's an .070 section ring with ID of about.48" Have not done this personally, but found this pixture in Patssle's engine swap thread |
Larmo63 |
Oct 30 2016, 11:40 AM
Damn, one would think that might be 1st on your list. Oh well, your a lucky man and good on ya. poke.gif Now get back to work so you can make Rt 66 in your 914. beerchug.gif Kent
I know, but I was busy driving the heck out of the car. I just never got around to it. |
Larmo63 |
Oct 30 2016, 03:53 PM
Krieger |
Oct 30 2016, 05:12 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Your going to put some sort of grommet in there right?
Oct 30 2016, 05:40 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You know, on mine I don't have any grommets. If I see it start to fray I'll do something about it but our race car mechanic said not to bother.
Larmo63 |
Oct 30 2016, 07:10 PM
No grommets needed if you have both ends clamped to the body. no lateral movement. This hose is very tough and it's a tight fit. The holes are not sharp or jagged, I think it will be fine.
Larmo63 |
Oct 30 2016, 07:16 PM
I've got a call in to Jesus, er, ah, um, I mean James Patrick to pick his brain a little bit on the design/layout of the oil cooling system I'm installing.
76-914 |
Oct 30 2016, 09:14 PM
No grommets needed if you have both ends clamped to the body. no lateral movement. This hose is very tough and it's a tight fit. The holes are not sharp or jagged, I think it will be fine. You think. Those are usually the things that bite you in the ass. As Chris H. said, "Everything I did half assed I'm re-doing now". (IMG:style_emoticons/default/av-943.gif) Why not do it to perfection. It's cheap. Order some of these http://www.aircraftspruce.com/catalog/hapa...napbushings.php then stop by and borrow some of my hole punches. You'll just need an crescent wrench to use them. |
Chris H. |
Oct 30 2016, 11:12 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
As Chris H. said, "Everything I did half assed I'm re-doing now". (IMG:style_emoticons/default/av-943.gif) That is 100% true. Can't wait to weld up the holes I made in the trunk that I didn't need (IMG:style_emoticons/default/headbang.gif). |
Larmo63 |
Oct 31 2016, 06:21 PM
I'm actually trying to avoid drilling any holes that aren't necessary. This is taking me a while because I have to think it all out and do it how I see doing it.
Larmo63 |
Dec 30 2016, 07:29 PM
Nothing like reading the Route 66 thread and WCR in Mammoth to get the /6 conversion juices flowing again. I'm fucking sick of seeing this beautiful car up on jack stands in my garage.
I'm back at it with new vim and vigor. Little by little, I might just get this running in time for Temecula. |
Lo-Fi Version | Time is now: 5th May 2024 - 09:57 PM |
