Uhh-Ohh…., My Ongoing 914 Build Adventures.... |
porschetub |
May 4 2017, 12:19 AM
I have that Bruce Anderson book. I can't read, but I do look at the pictures quite a bit. (IMG:style_emoticons/default/beerchug.gif) Lawrence don't get into that work,just get the lump in there ,Nascar is nascar ,Porsche design logic is up there ,you need to maintain power in your normally driving range RPM otherwise it won't be easy to drive,mods are great but you have to read up and find an equal balance of drivability against top end power...enough of my rant. Good luck man (IMG:style_emoticons/default/beerchug.gif) |
ljubodraz |
May 4 2017, 06:03 AM
Member Group: Members Posts: 64 Joined: 4-May 14 From: Chicagoland Member No.: 17,312 Region Association: Upper MidWest |
Actually, I'm trying to take an intelligent approach to the task I've taken on. I am in agreement with McMark's comment. Also, it may be time to just let this thread die. Please don't let your thread die. (IMG:style_emoticons/default/popcorn[1].gif) I wish you the best in completing your goals in one way or another. If it were easy... insert wise quote here. |
get off my lawn |
May 4 2017, 04:29 PM
Member Group: Members Posts: 168 Joined: 18-August 11 From: west coast Member No.: 13,462 Region Association: None |
I know a guy who has been building a show quality muscle car for a long, long time.
When i say building, I mean he writes checks and breaks out the credit card. About two years into the project I told him that he would never ever finish that car and that would be intentional, by design. he said I was FOS but I went on to explain that he was in love with the dream, the fantasy. If he ever finished the car he would have to accept that it is not absolutely perfect in every way and that it didn't live up to his dreams. That scares him so he'll never finish the car because he doesn't want to. Again he said I was FOS. Fast forward 13 years later the car was ALMOST done, but he decided it needed a color change. And it now needs an automatic transmission instead of the $3500 manual he had installed. He has at least $70k into it already but he will never drive that car. Some folks dream of finishing a project, for some the project IS the dream. In summary, PUT THE DARN CAR TOGETHER! Please. (IMG:style_emoticons/default/welder.gif) |
76-914 |
May 4 2017, 04:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Perfection ain't Lar's problem. He's a slop artist like most of us. He just does this for the attention. (IMG:style_emoticons/default/biggrin.gif)
Larmo63 |
May 6 2017, 06:25 PM
Question about mounting the fuel pump.....
Hard mount, or rubber bushings? I know it needs to be grounded too. |
porschetub |
May 6 2017, 08:58 PM
Interesting choice of pumps,appears NOS ,I have a nice shiny NOS Hardi and never used it,where do you plan to mount it ?.
Seem to remember them rubber mounted,if you need mounts I think the early BMW 3 and 5 series AFM/airbox ones work if your mounting holes are 6mm. No pressure regulator required for the pump you have which is a bonus. |
Larmo63 |
May 6 2017, 09:30 PM
I sourced it from Australia, I'm mounting it up front....
You'll see. |
Steve |
May 7 2017, 08:07 AM
914 Guru Group: Members Posts: 5,571 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
McMark |
May 7 2017, 08:12 AM
Larmo63 |
May 15 2017, 06:50 PM
Some more welding to be done tomorrow, bottom front trunk metal with louvers, and oil cooler. Once that is done and painted, the oil cooler, oil cooler lines, thermostat, fuel pump, and fuel tank & lines all go in.
***I'm putting the spare receiver on the front bulkhead, anybody got a 15" space saver tire that they can measure for me?*** Diameter needed. Thank you. I'm excited to move to the back of the car now, I think that is near where the motor is going to go. (IMG:style_emoticons/default/beer.gif) |
'73-914kid |
May 15 2017, 11:06 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Some more welding to be done tomorrow, bottom front trunk metal with louvers, and oil cooler. Once that is done and painted, the oil cooler, oil cooler lines, thermostat, fuel pump, and fuel tank & lines all go in. ***I'm putting the spare receiver on the front bulkhead, anybody got a 15" space saver tire that they can measure for me?*** Diameter needed. Thank you. I'm excited to move to the back of the car now, I think that is near where the motor is going to go. (IMG:style_emoticons/default/beer.gif) I can get you a diameter tomorrow evening after work. Or, you can drive down to Vista tomorrow evening, grab some tacos, and borrow mine, so you know it's in the right place? |
Larmo63 |
May 15 2017, 11:29 PM
Found it.....20.25" for either the 15" or the 16".....
Thanks!! |
JmuRiz |
May 16 2017, 08:14 AM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
My 15" 951 space saver is only 19.75" in diameter, and CRAZY light to boot.
(I plan to use them on the other car, should save me 10-15lb per corner!) |
Larmo63 |
May 16 2017, 09:15 PM
euro911 |
May 17 2017, 12:04 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
A bolt-on, eh?
mb911 |
May 17 2017, 05:53 AM
914 Guru Group: Members Posts: 6,822 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
No those look like the butt weld clamps. They work great.
76-914 |
May 17 2017, 07:40 AM
Yup. I just discovered there a 2 different grades of butt weld clamps.
Larmo63 |
May 17 2017, 08:34 AM
We ground down the middle squares to make them as thin as possible.
They work great for this application. |
Larmo63 |
May 21 2017, 08:46 PM
Larmo63 |
May 21 2017, 08:48 PM
Lo-Fi Version | Time is now: 4th May 2024 - 08:56 AM |
