Uhh-Ohh…., My Ongoing 914 Build Adventures.... |
porschetub |
Aug 15 2017, 11:42 PM
Check with Clewitt about the crankfire pulley,hopefully it isn't different,I used the 10 x 710 and no issues for a short time till it started making noise,not slipping just a PITA noise turned out I had worn pulley faces,ordered a new outer and hope that fixes it otherwise I will get my fan hub machined.
Be careful to set the belt tension right as the bearings in these altenators are fairly small and you don't want to strain the magnesium outer housing as I did and the fan blades rubbed. Getting close Lawrence (IMG:style_emoticons/default/aktion035.gif) . |
SixerJ |
Aug 15 2017, 11:58 PM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
9.5x710 or 10x710 should be correct. Did you move any shims between the pulley halves yet? (IMG:style_emoticons/default/agree.gif) Great progress! Fairly sure my 2.4 engine has or rather had 3 or 4 shims (have to admit I haven't done the last 2 services / alternator had to be replaced in that time frame) I do clearly remember the 1st time I did the belt, and it's amazing how much of a difference even adding or removing a single shim makes. I had to go out and buy some more the 1st time I did this job and also keep some in a packet tucked into the tool kit |
McMark |
Aug 16 2017, 11:10 AM
Just run a tape measure around the pulleys. 710 is 710mm is 28". The PET specifies 725 for 76-79 911. That might be your target. But I'd just measure it and round down since the belt sits down in the upper pulley, you're measurement would be the MAX size, not the ideal size.
Larmo63 |
Aug 16 2017, 11:13 AM
Or, I look for a 82mm pulley half.....?
Aug 16 2017, 11:23 AM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
9.5x710 or 10x710 should be correct. Did you move any shims between the pulley halves yet? (IMG:style_emoticons/default/agree.gif) Great progress! Fairly sure my 2.4 engine has or rather had 3 or 4 shims (have to admit I haven't done the last 2 services / alternator had to be replaced in that time frame) I do clearly remember the 1st time I did the belt, and it's amazing how much of a difference even adding or removing a single shim makes. I had to go out and buy some more the 1st time I did this job and also keep some in a packet tucked into the tool kit The pulley should have 6 shims. Adjustment is just moving the shims in front or between the pulley halves but never removing them completely. |
Larmo63 |
Aug 16 2017, 11:28 AM
Yes, all shims are present and accounted for.
McMark |
Or, I look for a 82mm pulley half.....? Sure... but you can head down to your FLAPS and get a belt today. There is something about pulley sizes, ratios, and rotational speed. But I don't feel like looking all that up. (IMG:style_emoticons/default/tongue.gif) |
Larmo63 |
Aug 16 2017, 11:38 AM
I believe that a larger pulley turns slower.....?
euro911 |
Aug 16 2017, 01:15 PM
Which did you change (go larger with)? ... Crank pulley or alternator pulley?
Larmo63 |
Aug 16 2017, 07:30 PM
euro911 |
Aug 16 2017, 08:20 PM
(IMG:style_emoticons/default/thumb3d.gif) ... then you'll have it up and running this w/e? (IMG:style_emoticons/default/driving.gif)
porschetub |
Aug 16 2017, 08:30 PM
9.5x710 or 10x710 should be correct. Did you move any shims between the pulley halves yet? (IMG:style_emoticons/default/agree.gif) Great progress! Fairly sure my 2.4 engine has or rather had 3 or 4 shims (have to admit I haven't done the last 2 services / alternator had to be replaced in that time frame) I do clearly remember the 1st time I did the belt, and it's amazing how much of a difference even adding or removing a single shim makes. I had to go out and buy some more the 1st time I did this job and also keep some in a packet tucked into the tool kit The pulley should have 6 shims. Adjustment is just moving the shims in front or between the pulley halves but never removing them completely. Six shims,not for the early motors 2 to 3 as far as I know but this a later motor so that may explain it? |
porschetub |
Aug 16 2017, 08:40 PM
Not sure, looks very low in the top pulley,perhaps a few less shims,the belt should be level with the top of the pulley halves or there abouts,try that. It needs to sit as your crank pulley or a little under.allowing for initial belt stretch. When its right you will have a really small deflection,around 10-12mm cause its a short belt,otherwise you may need something slightly longer if it appears too tight. |
McMark |
Aug 17 2017, 11:10 AM
Not sure, looks very low in the top pulley,perhaps a few less shims,the belt should be level with the top of the pulley halves,try that. It needs to sit like your crank pulley. If it's tensioned correctly, why would you care how low it sits in the upper pulley? The whole shim-based tensioning scheme pretty much guarantees the belt won't sit like the bottom pulley. If they wanted it to sit at the top every time the shim setup is a bad choice and a std pulley with tensioner would more effectively accomplish that. And... the higher the belt sits in the fan pulley, the longer the belt is. The belt sitting at the very top means that's the longest belt possible. And that means that if the belt stretches a bit over time, you have no more room for adjustment. I think the right, or better, answer to 'Where should be belt ride?' is... Anywhere, as long as: 1. The belt is tensioned correctly. 2. The belt sides are fully contacting the pulley walls. |
porschetub |
Aug 17 2017, 08:46 PM
Way I was taught,have edited my reply ok Mark.
Larmo63 |
Aug 17 2017, 10:12 PM
The belt deflection is close to 10mm in this set up.
I'm happy with it. Engine goes in tomorrow. |
Larmo63 |
Aug 17 2017, 10:23 PM
Larmo63 |
Aug 17 2017, 10:28 PM
By the way, when we had the heads off, we measured the pistons and they are 84mm. That means this engine is really a 2.4. We think the cams will give us milder "S" type performance numbers, along with the porting work we just did.
Oh, and also by the way, I was told the engine was built to a 2.7 spec and I bought it as such................ Oh well. I think it will be a fun car, nonetheless. |
Krieger |
Aug 17 2017, 10:59 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
(IMG:style_emoticons/default/piratenanner.gif) Dude, your almost there!
porschetub |
Aug 18 2017, 12:42 AM
By the way, when we had the heads off, we measured the pistons and they are 84mm. That means this engine is really a 2.4. We think the cams will give us milder "S" type performance numbers, along with the porting work we just did. Oh, and also by the way, I was told the engine was built to a 2.7 spec and I bought it as such................ Oh well. I think it will be a fun car, nonetheless. What the hell ,it will still go really well with that combo,nothing wrong with what you have,you should make 160-180hp easy (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) . |
Lo-Fi Version | Time is now: 7th May 2024 - 07:19 PM |
