Uhh-Ohh…., My Ongoing 914 Build Adventures.... |
IronHillRestorations |
Aug 27 2017, 06:20 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
It helps to be of smaller stature like me Lawrence, but I remember it was a lot easier 25 years ago. Taking out the seats helps,
Larmo63 |
Aug 27 2017, 08:18 AM
I took the driver's seat and the steering wheel out. Packing blankets on the floor of the garage and inside floor of the car help.
Still, the wiring under a 914 dash is hard to get to. I'd like to think that I got it all in one fell swoop. I still need to pick up a dash light jumper for the oil pressure gauge. I think that is the only thing left to do in the dash area. I may say it is a pain in the ass to do, but once I get into "wiring mode," I actually enjoy the challenge of point to point wiring. The German side of my brain comes into play. All of the routing I did is tidy, zip tied, up and out of the way. |
Steve |
Aug 27 2017, 09:03 AM
914 Guru Group: Members Posts: 5,571 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I remove the lower dash pad. It's just a screw on each end and several big ones underneath. After that just slide it back towards the rear of the car
76-914 |
Aug 27 2017, 09:13 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Don't get any wires near the steering u-joint. Ask me how I know. Try this: take a piece of 3/4" plywood ~17.5" x 13.5". When you remove the seat lay this piece on the seat track. I drove 2 nails thru the plywood that pass thru the square holes so it won't slide around. Just be sure to round off the end of the nails. Then put a cushion over the plywood. Quite comfortable! (IMG:style_emoticons/default/beerchug.gif)
Larmo63 |
Aug 27 2017, 11:09 AM
I used some thick black plastic wire guard above the U-joint. I had some old 914 wiring harnesses from my parts pile that I pilfered wires from.
I like that board idea, Kent. Why don't you market that? (IMG:style_emoticons/default/KMA.gif) I have had the kneepad out, Steve, but I didn't really need it out for this wiring. (IMG:style_emoticons/default/w00t.gif) |
Larmo63 |
Aug 27 2017, 11:11 AM
Dave Darling said it the best: "You're 90% done with 90% more to go."
That's where I'm at. |
Matty900 |
Aug 27 2017, 01:00 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
Wiring gauges and working under the dash of a 914 is NOT fun. Poor Trudy, she had to put up with my moans, groans, swearing, growling, sighing, grumbling, cursing, stomping, cajoling, barking, grunting, cursing, figuring, fussing, working, and finishing. It will (still) be a miracle if this all works. (IMG:style_emoticons/default/WTF.gif) I'm pretty confident it will. Although, I will be Amazed. I did the tach adapt box, fuel pump power, oil pressure gauge, and oil temperature gauge. On to other adventures tomorrow. My list grows shorter. Your not making me look forward to doing this in my car this week. How long did it take you? |
euro911 |
Aug 27 2017, 01:23 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
It helps to be of smaller stature like me Lawrence, but I remember it was a lot easier 25 years ago. Taking out the seats helps, True, but having a younger person with a resilient body would be better.Neat idea on the seat board, Kent (IMG:style_emoticons/default/idea.gif) ... I still have the driver's seat out of the 'BB' |
Larmo63 |
Aug 27 2017, 06:42 PM
Good thing your are a smaller guy too, Matt!!!
A couple afternoons. I'm making it sound worse than it really was. It almost gets addictive. Wiring gauges and working under the dash of a 914 is NOT fun. Poor Trudy, she had to put up with my moans, groans, swearing, growling, sighing, grumbling, cursing, stomping, cajoling, barking, grunting, cursing, figuring, fussing, working, and finishing. It will (still) be a miracle if this all works. (IMG:style_emoticons/default/WTF.gif) I'm pretty confident it will. Although, I will be Amazed. I did the tach adapt box, fuel pump power, oil pressure gauge, and oil temperature gauge. On to other adventures tomorrow. My list grows shorter. Your not making me look forward to doing this in my car this week. How long did it take you? |
Larmo63 |
Aug 27 2017, 06:44 PM
I hooked up the battery today and all systems seem to be good. Everything works.
Now, If I can get my carb guy back with my parts, I can pour oil and gas in. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
Larmo63 |
Aug 28 2017, 10:57 PM
porschetub |
Aug 28 2017, 11:38 PM
If your fuel pressure is right,and the carbs setup on a basic bench setup,it will run...turn the bloody key ok (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) .
Get those vw beetle style tail pipes sorted too when your carb parts have been sorted ok (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) . |
Larmo63 |
Aug 29 2017, 07:11 PM
914_7T3 |
Aug 29 2017, 07:31 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,847 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
porschetub |
Aug 29 2017, 09:59 PM
Larmo63 |
Aug 29 2017, 10:03 PM
The only offense is if it doesn't sound great!!!!
Larmo63 |
Aug 29 2017, 10:53 PM
Fuel lines hooked to fuel regulator up this afternoon. I'm this close. If I can get our carb guy to respond, I think we will start it by the weekend. He has a few crucial parts of mine that I need to get from him. I may have depended and trusted that I would get these parts back sooner. I don't want to say too much, but his communication skills are.....never mind.
Blue6 |
Aug 29 2017, 11:02 PM
Senior Member Group: Members Posts: 1,034 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
I removed mine for a triad. It was just toooo quiet... |
'73-914kid |
Aug 29 2017, 11:28 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Lawrence, what kind of carb parts are you missing? I have a decent collection of 3BBL IDA parts in a box at home. might help you get the ball rolling quicker.
914_teener |
Aug 29 2017, 11:40 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Lo-Fi Version | Time is now: 4th May 2024 - 12:59 PM |
