Uhh-Ohh…., My Ongoing 914 Build Adventures.... |
Larmo63 |
Sep 10 2017, 10:23 PM
The car is up and running, just not running perfectly. The devil is in the details. I may chance it and drive it to Temecula.
Issues: Most of my gauges are not working at all or not working right, and I hate working under that dash Carbs are farty and still a bit off, we played with them yesterday Linkage is shit - hate it I can't seem to find affordable air cleaners for the Webers Kind of disappointed in a few things, but I'm moving forward. The tire shop really fuched up two of my beautiful wheels Saturday. It's going to cost her $500 to fix them. When I'm driving the car and the engine is singing behind me, I'm okay. |
ConeDodger |
Sep 10 2017, 10:24 PM
Apex killer! Group: Members Posts: 23,574 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Excellent Lawrence! (IMG:style_emoticons/default/evilgrin.gif)
porschetub |
Sep 10 2017, 11:12 PM
The car is up and running, just not running perfectly. The devil is in the details. I may chance it and drive it to Temecula. Issues: Most of my gauges are not working at all or not working right, and I hate working under that dash Carbs are farty and still a bit off, we played with them yesterday Linkage is shit - hate it I can't seem to find affordable air cleaners for the Webers Kind of disappointed in a few things, but I'm moving forward. The tire shop really fuched up two of my beautiful wheels Saturday. It's going to cost her $500 to fix them. When I'm driving the car and the engine is singing behind me, I'm okay. Singing behind you ...yep thats what its all about,carbs don't tune in a hurry ...ask me how I know (IMG:style_emoticons/default/headbang.gif) ,if you have no spit back after the engine is warmed you are generally close,any popping @ the exhaust try screwing in the mixture screws slightly if your idle jets are right you will have a good result. Post what jetting/vent size you have someone may chime in ...just don't run it too rich,again ask me how I know. Do you have one of these; And get yourself a PMO float bowl gauge real hand also; Sure Keith will get on to it ,I'am on my 3rd carb tune and feel I'am closer to that sweet spot,good luck. |
Larmo63 |
Sep 11 2017, 12:23 AM
On the idle jets, we tried 60s and 55s, went back to 60s.
Float bowl levels are perfect, I will list tomorrow. |
gereed75 |
Sep 11 2017, 06:37 AM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I have a 2.4 with 9.5, ported heads to 36mm and DC30 cams.
I put in a fair amount of work on the carb tuning using a wide band O2 sensor. Carbs completely rebuilt and blue printed. Car runs pretty consistently in the 12 to 13 AFR range pretty much everywhere. Can't remember the exact set up but includes 60 idles ,32 venturis, f26 tubes. Will look back at my records later today for the rest. It still pops farts and snorts. Might be the nature of the beast with these cams and set up. By the way, love it and it makes plenty of grunt. Smooth and clean down low, surprisingly torquey, with a good surge above 5000 rpm right up to 7200 redline. Nice! Don't obsess so much - run it! Oh yea, Not sure if your talking about the carb or shift lineage but I got a Weltmiester short shifter and Chris's shift kit with the extra rear console bearing - shifts pretty nicely once you are in the H. First to second still funky and just needs to be done slowly and deliberately, but no biggie. You know the drill. but I would say that Chris's setup is about as good as it gets. Have fun man! |
Larmo63 |
Sep 11 2017, 11:04 AM
Paul Abbott recommends:-----------------------------------I have:
34 chokes-----------------------------------------------------34 chokes 145 mains-----------------------------------------------------135 mains F3 emulsion---------------------------------------------------F26 emulsion 180 air correctors---------------------------------------------180 air correctors 55 idle jets-----------------------------------------------------55 and 60 idle jets (a set of each) I have Webers, DC-30 cams, and 36mm intake bores...... |
Steve |
Sep 11 2017, 11:26 AM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Paul Abbott recommends:-----------------------------------I have: 34 chokes-----------------------------------------------------34 chokes 145 mains-----------------------------------------------------135 mains F3 emulsion---------------------------------------------------F26 emulsion 180 air correctors---------------------------------------------180 air correctors 55 idle jets-----------------------------------------------------55 and 60 idle jets (a set of each) I have Webers, DC-30 cams, and 36mm intake bores...... Interesting... Bruce's book recommends the same thing except it recommends 145 air jets. And all the above was for a 2.7, not a 2.4. |
'73-914kid |
Sep 11 2017, 12:16 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
34mm vents are probably a little too big with the DC-30's for street driving.. like ly not enough port velocity at low RPM, especally with the enlarged intake port. I wold go down to a 32, and mimic Bruce's jetting recommendations for a 2.4L with S cams.
mb911 |
Sep 11 2017, 12:40 PM
914 Guru Group: Members Posts: 6,819 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Are Dc 30s s cams? Just curious
JmuRiz |
Sep 11 2017, 02:06 PM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
DC-30 = Mod Solex
DC-40 = Mod S So basically it's a bit improved over a Solex cam...great for the street! |
Lucky9146 |
Sep 11 2017, 02:28 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,607 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Larmo63 |
Sep 11 2017, 05:31 PM
I just took out the idle jets to downsize to 55s, but discovered that I had 5 55s and one 60. So I stayed with the 60s for now. I fiddled some with the linkage, and what I did made a huge improvement in performance and the initial flat spot. I didn't have the linkage set up quite right per Rich Johnson's instructions. I fixed that today. I drove the car and it really REALLY is improving.
One note, I let the clutch cable out (loosened) a few turns, it seems like it clutches closer to the floor. Was I supposed to tighten the cable? It goes against my thought process.... |
Steve |
Sep 11 2017, 08:33 PM
Tightening the cable reduces the freeplay which makes it engage and disengage closer to you versus the floor. I adjust for 1/2" freeplay
IronHillRestorations |
Sep 11 2017, 09:12 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If you have the venturis and jets, I'd probably try 32's with 145 mains, 180 air, and 60 idle, and stick with the F3's. You'll give up a smidgen on the top end, but improve transition between idles and mains. Emulsion tubes can make more of a difference than a lot of guys realize, F26 or F11's could make a difference. Of course getting a bunch of jets, venturi, and e-tubes gets spendy. One tip here: change only 1 thing at a time or you'll have a difficult time dialing it in.
You don't want your clutch cable too loose, or you'll smoke the friction disc. Steve is on the money, get it down to 1/2 of free play, then you adjust the stop on the pedal board so when you stop, clutch, and shift to R it doesn't grind. It's kind of a PITA but you should only have to do it once. If you want you can give me a call tomorrow Lawrence, I might be able to help a bit. |
Catorse |
Sep 12 2017, 09:58 AM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
I gassed up the car, drove over to Catorse's house (Adam) and really put the car through it's paces. It needs a bit of carburetor attention, but still, does it ever accelerate!!! I'm really happy with where I'm at with it, even if it's off a bit. It gives me something to tinker with. I just hope I can get it reigned in for the fun day thing in Temecula next - next weekend. I already have tuning plans for this weekend........ Best regards to Adam !....MSDS equipped Gen-2 928 racing headers on his rare 928 racer (IMG:style_emoticons/default/driving.gif) Marty Back at you buddy! |
forrestkhaag |
Sep 12 2017, 10:14 AM
I will see you at keiths place this afternoon / I will pick up spare Venturi's if you want to try them out.,.
(IMG:style_emoticons/default/beerchug.gif) |
Larmo63 |
Sep 13 2017, 10:16 AM
We had the carbs off of the car and were taking them apart when Forrest showed up with the "do you want the good news or the bad news first?" comment. He brought 30 chokes, so we will try to source some 32s today. I put 55 idles in, car ran lousy on the way home. I'll put the 60s back in. Cause and effect.
Forrest and Keith |
gereed75 |
Sep 13 2017, 10:55 AM
Sorry I forgot to check my carb specs. I do know the 55 idles just do not work. Tried that.
Definitely have 60's, 32, F26 in mine and I think 145 mains and 180 airs. Getting the 32 venturi's might be key to get the right velocities so all the jets/secondaries work right. Getting the carbs right is like building a building - foundation must be sound or you are wasting your time. Start with good linkages (blueprinted), then right fuel pressure (3 psi), Then the right throttle plate height (once you get this do not change it!), then right float levels (blue printed floats). Then accel pump output, Then idles and venturis. If you get all that then you tune using airs, mains and tubes. .....and then if you get all that right..... flat six nirvana!! If you don't....... crap! It can be a serious PITA. Be patient and thorough. Performance Oriented tech docs are really good!! |
Steve |
Sep 13 2017, 10:58 AM
euro911 |
Sep 13 2017, 11:18 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,846 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Thanks for linking the jet chart, Steve. Those #s will come in handy for re-jetting some carbs for the 912 (1.7L big-bore) motors (IMG:style_emoticons/default/aktion035.gif)
Lawrence, do you have an AF meter there? I can bring a LM-2 kit yo the Temecula gig (if I can remember where I put it) ... Maybe you should have subscribed to JET magazine (IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:49 PM |
