37 Pages V « < 33 34 35 36 37 >
> Uhh-Ohh…., My Type IV to 911 engine conversion adventures....
Larmo63
post Dec 5 2017, 08:33 PM
Post #681
Fuses look good.
Lucky9146
post Dec 5 2017, 08:44 PM
Post #682
It is fuse 7 just verified on my car. You didn't accidentally rotate the light switch to off did ya? (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/white914.jpg)
Dave_Darling
post Dec 5 2017, 09:51 PM
Post #683
914 Idiot
Come on, you know that the fuses "look" good even when they're popped. Check them for real.
--DD
Coondog
post Dec 5 2017, 11:16 PM
Post #684
You need to install a J-West fuse box in that beast....... (IMG:style_emoticons/default/first.gif) Gregs top ten 10 mods under 100 dollars.
Larmo63
post Dec 6 2017, 12:13 AM
Post #685
I fiddled with it, then got called in for dinner. I'm not even hungry when I want to work on my toy.
More on this tomorrow. I'll look closer at the fuses.
Larmo63
post Dec 6 2017, 04:39 PM
Post #686
That's so weird, I looked closer at the fuses, lo and behold, #7 was popped. I traced it back to wonky wires in the license plate light wiring that was a bit brittle and was shorting out. Now the dash lights and both license plate lights work.
I'm glad I figured that out. (IMG:style_emoticons/default/KMA.gif)
euro911
post Dec 7 2017, 01:15 AM
Post #687
I had an issue on the '71 several years ago, the engine would intermittently cut out and it was driving me crazy. Ended up being a fuse on the relay board - broken right at the end where the metal transitions to the end cup form that inserts into one of the holder tangs.
Only found the problem by removing the fuse from the holder to clean the tangs ... looks are deceiving.
Coondog
post Dec 7 2017, 03:33 AM
Post #688
Just Do It............ (IMG:style_emoticons/default/poke.gif)
Dave_Darling
post Dec 7 2017, 03:02 PM
Post #689
914 Idiot
QUOTE(Larmo63 @ Dec 6 2017, 02:39 PM) *
... lo and behold, #7 was popped....
Toldja. I really don't want to try counting the number of popped 914 fuses I have found only when I have removed the fuse from the panel...
--DD
Larmo63
post Dec 7 2017, 05:59 PM
Post #690
QUOTE(Dave_Darling @ Dec 7 2017, 01:02 PM) *
--DD
Yup, you were right. I owe you one...... (IMG:style_emoticons/default/beerchug.gif)
post Dec 7 2017, 06:16 PM
Post #691
914-6 GT in waiting
QUOTE(Larmo63 @ Dec 7 2017, 06:59 PM) *
--DD
Ahem?
Larmo63
post Dec 7 2017, 07:49 PM
Post #692
Mea culpa. I always seem to make electrical issues into something bigger (and scarier) in my empty head.
Practical and pragmatic investigation proved that the issue was cracked license plate wires to which I put new ends on cleanly stripped wire with new shrink tube.
You guys were right...........
post Dec 7 2017, 08:14 PM
Post #693
914-6 GT in waiting
QUOTE(Larmo63 @ Dec 7 2017, 08:49 PM) *
45 year old cars....
post Dec 7 2017, 09:37 PM
Post #694
Repeat Offender
QUOTE(Larmo63 @ Dec 7 2017, 05:49 PM) *
This is exactly why you shouldn't do the JWest fuse box. (IMG:style_emoticons/default/av-943.gif) Search "license plate lights" and you'll find your not alone. Those chicken shit little bastards have bitten a lot of peeps in the ass.
porschetub
post Dec 8 2017, 02:58 PM
Post #695
QUOTE(Larmo63 @ Dec 8 2017, 02:49 PM) *
I wouldn't worry about we have all done the same @ one stage or another,my electrical skills are somewhat lacking,however it go's I generally get there. (IMG:style_emoticons/default/biggrin.gif) .
There seems to be 2 camps on the J-West board.....what gives (IMG:style_emoticons/default/confused24.gif) .
post Dec 8 2017, 03:19 PM
Post #696
914-6 GT in waiting
QUOTE(porschetub @ Dec 8 2017, 03:58 PM) *
I think people buy it to try to solve a problem. Got to fix problems first.
Larmo63
post Dec 14 2017, 04:34 PM
Post #697
I had my car up at Richard's shop in San Clemente. It's nice to get a real 911 expert to look your build over and tune the car. He re-jetted the carbs, re-torqued the heads and adjusted the valves.
It runs so much better, it was lean all around. He also caught a few loose bolts here and there, gave it the once over.
raynekat
post Dec 14 2017, 04:42 PM
Post #698
QUOTE(porschetub @ Dec 8 2017, 12:58 PM) *
My take on why people "like" the JWest fuse panel....mainly for the modern blade fuses.
I didn't like the way the wires were directed into the JWest fuse panel.
Seemed like you had to bend the wires 180 degrees on one side, so that could with time stress those wires out and give you big electrical headaches down the road.
I simply cleaned up my factory fuse panel, installed all new fuses and enjoyed the way the wiring all connected to panel without any crazy 180 degree bends like one side of the JWest panel had.
Coondog
post Dec 14 2017, 04:51 PM
Post #699
QUOTE(Larmo63 @ Dec 14 2017, 03:34 PM) *
(IMG:style_emoticons/default/first.gif) Always nice to have a third party go over your build.
Larmo63
post Dec 14 2017, 06:28 PM
Post #700
I just took a nice drive down the coast through Camp Pendleton....car is running right.
- Lo-Fi Version Time is now: 25th September 2018 - 09:35 PM
