Uhh-Ohh…., My Ongoing 914 Build Adventures.... |
Larmo63 |
Oct 10 2016, 07:40 PM
I'm doing all the construction stuff first, then the pretty.....
Bulldog9 |
Oct 11 2016, 10:40 AM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Larmo63 |
Oct 15 2016, 05:39 PM
What do you do with the relay board when doing a conversion?
Move it? Remove it? Keep it?? (IMG:style_emoticons/default/idea.gif) |
ClayPerrine |
Oct 15 2016, 05:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
What do you do with the relay board when doing a conversion? Move it? Remove it? Keep it?? (IMG:style_emoticons/default/idea.gif) I leave it in and use it to hold the voltage regulator. If you run an internally regulated alternator, you can remove it. If you are running an early 911 engine, you will need to find some place to put a tach amplifier. Without one, the tach won't work. The factory used the 914-6 relay board for that, but you could put it in behind the tach. |
Steve |
Oct 15 2016, 06:00 PM
914 Guru Group: Members Posts: 5,569 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
What do you do with the relay board when doing a conversion? Move it? Remove it? Keep it?? (IMG:style_emoticons/default/idea.gif) I dumped it 30 years ago. Never missed it. |
Larmo63 |
Oct 15 2016, 06:04 PM
I'm going to use the Clewett Engineering ignition set-up which I think has its' own wire to the tach.
http://www.clewett.com/index.php?main_page...p;products_id=2 |
Steve |
Oct 15 2016, 07:21 PM
I would check with Clewett for recommendations. Otherwise 30 years ago I bought a 914 and 911 Haynes manuels and did a stare and compare. Both the 911 and 914 tach have a black and purple wire that goes from the tach to pin 1 on the coil. All I did was replace the tach with a 911 tach and trace the wires with an volt ohm meter. Pretty simple.
Larmo63 |
Oct 15 2016, 09:51 PM
Steve |
Oct 15 2016, 10:24 PM
Nice!!! The real sixes had the relay board. I liked the extra room, so I dumped it. I used a 928 connector to connect to the plug that plugs into the relay board. I made my own harness. Patrick sells the same thing. A carbureted engine is very simple.
Larmo63 |
Oct 16 2016, 12:08 AM
I'm just planning out how all of this goes together and I'd rather not have the board in there if I can help it. I'd like to grind the holders out now, before I detail, weld, and paint the engine compartment.
Thank you for all the help and suggestions! (IMG:style_emoticons/default/beerchug.gif) |
Steve |
Oct 16 2016, 07:44 AM
I'm just planning out how all of this goes together and I'd rather not have the board win there if I can help it. I'd like to grind the holders out now, before I detail, weld, and paint the engine compartment. Thank you for all the help and suggestions! (IMG:style_emoticons/default/beerchug.gif) Just make sure your alternator has a built in regulator. Mine did. I still have receipt somewhere for the plug to build a harness. Pretty simple. |
Larmo63 |
Oct 16 2016, 06:48 PM
I was going to have Kroon do my harness.
porschetub |
Oct 17 2016, 03:20 AM
Oct 17 2016, 05:10 AM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I was going to have Kroon do my harness. Why? Perry did mine and real happy,uses standard relay board and it all works,great workmanship,he can custom build also. (IMG:style_emoticons/default/agree.gif) save the overseas shipping and long turn around. Perry's your man. |
Catorse |
Oct 17 2016, 08:14 AM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
Harness? Come on Lawrence there's like 5 wires there!
Larmo63 |
Oct 24 2016, 08:27 PM
McMark |
Oct 25 2016, 11:13 AM
Smart!
euro911 |
Oct 25 2016, 11:34 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Cool idea, but can't we find a cap nut to do the same thing? Anybody know what size and TPI is that bung is?
Catorse |
Oct 25 2016, 12:03 PM
A cap nut would not seal as well. When you torque this down, you have a press fit on the tit that sticks out, which plugs the hole. THEN, the aluminum on the top side crushes against the nipple on the gas tank, like a crush washer. So it won't leak for sure.
That's the idea behind it. A cap nut would rely 100% on the threads to seal it which is sketchy for gas. |
euro911 |
Oct 25 2016, 02:16 PM
Not if a fibrous washer or an impervious rubber gasket were used in the cap nut.
Lo-Fi Version | Time is now: 25th April 2024 - 04:49 AM |
