It went up in flames ... Twice |
vnault |
Apr 16 2016, 09:16 PM
Newbie Group: Members Posts: 44 Joined: 20-September 15 From: Sherbrooke,qc Member No.: 19,182 Region Association: None |
Well today is a sad day.
I had an appointment to the garage d'o install a thousand dollars worth of parts on my recently bought 914 for my 35th birthday.... Also I wanted them to check for the strong fuel odor since I got it out after the winter. Today it was the first really hot day... 19 degree C and it was sunny. I took the car out... 5 miles of slow driving.... I hear a strange "glurp" while accelerating.... I look back, there was smoke, flame ... I park get my girl to safety, I found water... I extinguished the fire.... Before the firefighter arrived....still they gave the engine bay good rince. I towed the car to a nearby garage... I think there was still something to do with the car. I put a cover on the car and I go home. 6 hours later the police call to tell me that my car was on fire...again. I and the firefighter did not think about disconnecting the batterie.... Probably a spark.... I don't know what h will do. Attached thumbnail(s) |
Justinp71 |
May 27 2016, 10:45 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
We should make a fire prevention annual check list. What are items that should be checked on an annual basis to prevent fires? -Fuel Lines -Carb bolts (if equipped) -Main power feeds from battery are in good shape and not rubbing anywhere on the car -Fire prevention system intact (fire extinguisher or other) -??? We could make a template available for printing and people can give there cars a once over every year. If you guys PM me with items I will volunteer to make this template (unless it exists somewhere?) |
vnault |
May 27 2016, 11:52 AM
We should make a fire prevention annual check list. What are items that should be checked on an annual basis to prevent fires? -Fuel Lines -Carb bolts (if equipped) -Main power feeds from battery are in good shape and not rubbing anywhere on the car -Fire prevention system intact (fire extinguisher or other) -??? We could make a template available for printing and people can give there cars a once over every year. If you guys PM me with items I will volunteer to make this template (unless it exists somewhere?) I think a good maintenance on the carbs after the winter would have saved me a lot of trouble and dollars. I will now carry a fire extinguisher and I will look into that 3M system. |
Justinp71 |
May 27 2016, 02:40 PM
We should make a fire prevention annual check list. What are items that should be checked on an annual basis to prevent fires? -Fuel Lines -Carb bolts (if equipped) -Main power feeds from battery are in good shape and not rubbing anywhere on the car -Fire prevention system intact (fire extinguisher or other) -??? We could make a template available for printing and people can give there cars a once over every year. If you guys PM me with items I will volunteer to make this template (unless it exists somewhere?) I think a good maintenance on the carbs after the winter would have saved me a lot of trouble and dollars. I will now carry a fire extinguisher and I will look into that 3M system. I thought you had an electrical fire? Did you ever find the root of your fire? The only only item on carbs that wears is the fuel line going to them, but it would be good to check all the brass nuts and bolts for tightness and also look it over for leaks when the fuel pump is on occasionally. |
Lo-Fi Version | Time is now: 13th May 2024 - 12:45 PM |
