It went up in flames ... Twice |
vnault |
Apr 22 2016, 06:09 PM
Newbie Group: Members Posts: 44 Joined: 20-September 15 From: Sherbrooke,qc Member No.: 19,182 Region Association: None |
It's not as bad as I originally thought (mechanically). You'll need an engine compartment relay box Round relays and a voltage regulator Engine and alternator wiring harnesses ... and possibly new battery cables Distributor cap and sparky wires ... (maybe a distributor) Possibly an alternator (and belt) Driver side carburetor will need to be evaluated to see if it's salvageable ... if so, you'll need a rebuild kit (might as well get two and do both) Your tins look like they'll clean up OK (bead blast & repaint) Engine bay rubber seals may need replaced (914 rubber has a nice kit) Others may chime in, as I may have missed a couple of things ... I'll check my inventory and let you know what I have laying around Everything you mentioned I probably have on a shelf or in a drawer, including carb rebuild kits. Waiting for an estimate! |
ChrisFoley |
Apr 23 2016, 12:24 PM
I am Tangerine Racing Group: Members Posts: 7,894 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Waiting for an estimate! I worked on it some today, should be ready to email on Monday. (IMG:style_emoticons/default/smile.gif) |
vnault |
Apr 23 2016, 12:53 PM
Waiting for an estimate! I worked on it some today, should be ready to email on Monday. (IMG:style_emoticons/default/smile.gif) I can not thank you enough for putting of your own time into this. |
vnault |
May 25 2016, 02:57 PM
The car is on its way to Chris Foley ... thanks to Jody from Whitehorse transportation for the great price and service.
Lets hope for a painless resurrection. Vincent Attached thumbnail(s) |
May 25 2016, 03:03 PM
Resident German Group: Admin Posts: 41,580 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
mark04usa |
May 25 2016, 03:29 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
(IMG:style_emoticons/default/piratenanner.gif) Vincent, Happy to hear that your car is going to be fixed up right and proper. You'll be enjoying it again soon!
EdwardBlume |
May 25 2016, 04:07 PM
euro911 |
May 25 2016, 04:48 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
GregAmy |
May 25 2016, 08:23 PM
Advanced Member Group: Members Posts: 2,262 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
May 25 2016, 08:30 PM
Custom Member Group: Members Posts: 24,498 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You are in very good hands
stugray |
May 25 2016, 09:23 PM
I could donate a relay board and maybe a dizzy if necessary.
I also have a whole harness in a box with two relay boards. Interesting how it looks like the voltage regulator melted into a puddle. |
JRust |
May 25 2016, 09:51 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Ditto on sending it to the right person! You'll come out in the end a happy man. Takes a bit to get past it but your on the right track.
May 26 2016, 05:36 AM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You are in very good hands (IMG:style_emoticons/default/agree.gif) 100 percent the right person to get the car back on the road. |
ChrisFoley |
May 26 2016, 08:16 AM
ChrisFoley |
May 26 2016, 08:19 AM
stugray |
May 26 2016, 09:44 AM
I could donate a relay board and maybe a dizzy if necessary. I'll gladly install any donated items. Post a list of needed parts once you get a good look. And I assume one of the first things is to verify that the PO did not leave the stock Fuel Pump in for a carb install? |
May 26 2016, 09:50 AM
I could donate a relay board and maybe a dizzy if necessary. I'll gladly install any donated items. Post a list of needed parts once you get a good look. And I assume one of the first things is to verify that the PO did not leave the stock Fuel Pump in for a carb install? Engine Fuel injection Fuel tank Wiring harness Hmmm....should cover it. |
2mAn |
May 26 2016, 10:29 AM
trying to see how long I can go without a 914 Group: Members Posts: 486 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
I was sad when I started to read this, but Im loving how its turning out
ChrisFoley |
May 26 2016, 10:47 AM
May 26 2016, 12:11 PM
Lo-Fi Version | Time is now: 28th March 2024 - 05:26 AM |
