It went up in flames ... Twice |
vnault |
May 26 2016, 02:06 PM
Newbie Group: Members Posts: 44 Joined: 20-September 15 From: Sherbrooke,qc Member No.: 19,182 Region Association: None |
Thanks for your support guys.
If you have parts that you want to send to Chris, I will be happy to cover shipping fees. |
HansJan |
May 26 2016, 06:42 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Wow. Just read this for first time now.
This is awfull. I know how awfull it is, because mine burned last month. The silver lining for me has been that it has been the opportunity to go through the entire car. People on this site are incredibly helpfull. This afternoon I installed the stainless steel fuel lines (from Chris). Please do the same. Im doing (learning) all the work myself, and spend approx $2K in parts. However not yet repainted. Can't imagine how much labor would be. But you are in good hand with Chris. Good luck. Hans Jan Attached thumbnail(s) |
vnault |
May 26 2016, 07:26 PM
Hans Jan Your car burnt more then mine! It is great that you are able to save it. I would have like to be able to do and learn and do the work by myself but I am a small business owner with 3 kids and trying to finish my PhD (IMG:style_emoticons/default/headbang.gif) . Free time is scarce... This community found that car for me and will now save it. |
db9146 |
May 26 2016, 08:29 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I know this might be a little late for some but I just installed the 3m version of BlazeCut under the engine deck lid of my -6. If your haven't seen how it works, check it out on-line. There is a video demo on a VW bus and it works. For $129, its good insurance.
Justinp71 |
May 27 2016, 10:45 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
We should make a fire prevention annual check list. What are items that should be checked on an annual basis to prevent fires? -Fuel Lines -Carb bolts (if equipped) -Main power feeds from battery are in good shape and not rubbing anywhere on the car -Fire prevention system intact (fire extinguisher or other) -??? We could make a template available for printing and people can give there cars a once over every year. If you guys PM me with items I will volunteer to make this template (unless it exists somewhere?) |
vnault |
May 27 2016, 11:52 AM
We should make a fire prevention annual check list. What are items that should be checked on an annual basis to prevent fires? -Fuel Lines -Carb bolts (if equipped) -Main power feeds from battery are in good shape and not rubbing anywhere on the car -Fire prevention system intact (fire extinguisher or other) -??? We could make a template available for printing and people can give there cars a once over every year. If you guys PM me with items I will volunteer to make this template (unless it exists somewhere?) I think a good maintenance on the carbs after the winter would have saved me a lot of trouble and dollars. I will now carry a fire extinguisher and I will look into that 3M system. |
Justinp71 |
May 27 2016, 02:40 PM
We should make a fire prevention annual check list. What are items that should be checked on an annual basis to prevent fires? -Fuel Lines -Carb bolts (if equipped) -Main power feeds from battery are in good shape and not rubbing anywhere on the car -Fire prevention system intact (fire extinguisher or other) -??? We could make a template available for printing and people can give there cars a once over every year. If you guys PM me with items I will volunteer to make this template (unless it exists somewhere?) I think a good maintenance on the carbs after the winter would have saved me a lot of trouble and dollars. I will now carry a fire extinguisher and I will look into that 3M system. I thought you had an electrical fire? Did you ever find the root of your fire? The only only item on carbs that wears is the fuel line going to them, but it would be good to check all the brass nuts and bolts for tightness and also look it over for leaks when the fuel pump is on occasionally. |
patssle |
May 27 2016, 05:03 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
QUOTE The only only item on carbs that wears is the fuel line going to them Needle valves. They start getting sticky and all of a sudden your floats no longer stop the gas from coming in. This happened to me...immediately replace all 4 (on my flat-six carbs). |
rhodyguy |
May 28 2016, 08:42 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,061 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Examine the carb passageway lead plugs. When one looks further out than the others, it's time to pull the carbs and re-secure them.
vnault |
May 30 2016, 12:01 PM
From what I have been explained and reading... a sticky needle valve with a stuck floater would be the cause of my fire.
I hope Chris will be able to give me more informations soon. |
stugray |
May 30 2016, 03:44 PM
stuck needle valve or float will fill up the cylinders with fuel not necessarily overflow the carb.
If the car was running that is not likely the culprit. If it was sitting there not running, but with the fuel pump On, then maybe. |
vnault |
May 30 2016, 06:18 PM
stuck needle valve or float will fill up the cylinders with fuel not necessarily overflow the carb. If the car was running that is not likely the culprit. If it was sitting there not running, but with the fuel pump On, then maybe. The car was running, I suppose Chris Foley will enlighten us soon. |
ChrisFoley |
May 31 2016, 02:00 PM
I am Tangerine Racing Group: Members Posts: 7,910 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
stuck needle valve or float will fill up the cylinders with fuel not necessarily overflow the carb. If the car was running that is not likely the culprit. If it was sitting there not running, but with the fuel pump On, then maybe. The car was running, I suppose Chris Foley will enlighten us soon. The air cleaner is still in relatively good shape on top of the carb so there was no fire in the carburetor. The lead plugs are still in place. The fuel hose going to the carb is burnt up - just before the carb fitting. Fuel was leaking out of that hose when the flatbed was tilted to remove the car. So it appears that the hose may have been leaking enough to fuel the fire, not sure how it started yet. The second fire appears to be from burnt (alternator maybe) wires shorting out because the battery wasn't disconnected. |
vnault |
May 31 2016, 11:12 PM
Thanks for the update Chris!
Justinp71 |
Jun 1 2016, 12:18 PM
Good to know, fuel lines definitely have a lifespan. I am thinking of trying to remove some of my rubber lines in the engine bay and replace with as much hardline as possible. I think when I used to drag race they didn't allow more than 12" of rubber fuel line. |
JoeD |
Jun 1 2016, 12:40 PM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
I know this might be a little late for some but I just installed the 3m version of BlazeCut under the engine deck lid of my -6. If your haven't seen how it works, check it out on-line. There is a video demo on a VW bus and it works. For $129, its good insurance. Curious- what length did you use? 6'? 9'? This seems like a relatively cheap and easy step worth taking... |
ChrisFoley |
Jun 2 2016, 02:41 PM
euro911 |
Jun 2 2016, 04:13 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Chris,
Post a list of parts still needed when you get to that point. I may still have some parts I can look for - and donate (when I get back to AZ in July). |
larryM |
Jun 3 2016, 11:07 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
(IMG:style_emoticons/default/smash.gif) important for anyone reading this who has a 914 that still has the oem plastic lines: as a few others have suggested - get rid of the old oem plastic lines - it is a fire waiting to happen i've been up close to one of these - (not mine) no hand held fire extinguisher nor engine comp't extinguisher will be capable of putting out a fire at the fuel lines under the car if they crack/break & catch - the fuel will just run out from the tank in a big stream and keep on burning until the tank runs dry of course, an agile youth among us with fireproof hands might just be able lie on one's back and "strangle the leak" before he catches fire himself, eh? . |
ChrisFoley |
Jun 11 2016, 09:45 AM
Lo-Fi Version | Time is now: 27th April 2024 - 08:00 AM |
