Bearing whine noise |
mangrum |
Apr 18 2016, 09:37 AM
Member Group: Members Posts: 180 Joined: 10-September 03 From: Ann Arbor, MI Member No.: 1,134 |
Looking for some advice from the 914World brain trust.
I started my '72 1.7 yesterday, 1st time since last year, and there was a very noticeable bearing whine noise. Any ideas what could be the cause? Thanks, Mike |
tomrev |
Apr 18 2016, 09:41 AM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
[quote name='mangrum' date='Apr 18 2016, 07:37 AM' post='2332318']
Looking for some advice from the 914World brain trust. I started my '72 1.7 yesterday, 1st time since last year, and there was a very noticeable bearing whine noise. Any ideas what could be the cause? Thanks, Mike As in the engine alone, just running, or underway, as in wheel bearings, ext.? |
mangrum |
Apr 18 2016, 10:07 AM
As in the engine alone, just running.
[quote name='tomrev' date='Apr 18 2016, 11:41 AM' post='2332320'] [quote name='mangrum' date='Apr 18 2016, 07:37 AM' post='2332318'] Looking for some advice from the 914World brain trust. I started my '72 1.7 yesterday, 1st time since last year, and there was a very noticeable bearing whine noise. Any ideas what could be the cause? Thanks, Mike As in the engine alone, just running, or underway, as in wheel bearings, ext.? [/quote] |
tomrev |
Apr 18 2016, 10:29 AM
May be the alternator shaft bearing, or the through-out bearing for clutch. If the clutch, the sound should change when running, and in neutral, start pushing the clutch in; as bearing is loaded, it will change pitch, or get quiet.
mark04usa |
Apr 18 2016, 12:52 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
If it sounds a bit like a kazoo, could be the diaphram in the manifold pressure sensor...
Lo-Fi Version | Time is now: 21st May 2024 - 06:37 PM |
