Taillights - which should shine when? |
stevegm |
Apr 24 2016, 09:54 AM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
I've looked in the threads and can't seem to find this anywhere. Which of these lights should shine/blink when?
Same with front turn signal lights - Are they supposed to be dual element bulbs that shine when the lights are on and blink when the turn signal is on? Attached image(s) |
Mike Bellis |
Apr 24 2016, 10:09 PM
Right = Reverse
Center = park & brake (dual element) Left = turn far left = running light. |
stevegm |
Apr 25 2016, 05:31 AM
Hanks. The left and center alternate blinking when the turn signal is on. So I'm trying to figure it out.
Spoke |
Apr 25 2016, 02:40 PM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Hanks. The left and center alternate blinking when the turn signal is on. So I'm trying to figure it out. You have a ground issue. The center is brake/running light and should not be affected by the turnsignal (left). Check the ground wire on the bucket. Was this always happening or did you change something? |
Lo-Fi Version | Time is now: 21st May 2024 - 06:11 PM |
