Clutch lever arm - how's this look |
Amphicar770 |
Apr 30 2016, 08:11 PM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
dangrouche |
Apr 30 2016, 08:47 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
If 2mm was removed from the face of the flywheel, then you should be okay. If I were installing this, i would be threading the clutch cable through the trunion and and see how much thread adjustability exists. You should have a primary nut and a secondary nut to lock down the nut and flat washer that contacts the face of the trunion. Sorry,I did not realize you have not yet installed the assembly to the chassis. I believe my first statement is still accurate.
Lo-Fi Version | Time is now: 18th May 2024 - 06:54 PM |
