Car cutting off, It has a full tank |
ne14914 |
Jun 18 2003, 05:21 PM
Me N My914 Group: Members Posts: 94 Joined: 4-March 03 From: Los Angeles, Cali (Inland Empire) Member No.: 388 |
I have another problem (IMG:style_emoticons/default/headbang.gif)
Besides this mystery oil leak http://www.914world.com/bbs2/index.php?act...t=ST&f=2&t=2839 My car is just cutting off. Its like it doesnt have gas. It will start right back up. What should I check? And I cant find the fuel filter. Its not in hte trunk, under the car, or in the engine compartment. so - any help is appreciated. Extremely FRUSTRATED......... (IMG:style_emoticons/default/headbang.gif) |
Jeffs9146 |
Jun 18 2003, 05:54 PM
Does it cut off after running for a while or what? By "cutting off" does that mean it dies?
Need a bit more on this one! I had one that would warm up and then die when I came to a stop. It turned out to be stripped threds on the head temp sensor. Jeff |
tahoward |
Jun 18 2003, 06:36 PM
Member Group: Members Posts: 87 Joined: 30-December 02 From: Middletown, OH Member No.: 52 |
My 74 had a similar problem. I'm cruising and then nada. It sits a while...starts up and I cruise about a mile and nada again. It turns out my fuel tank was rusty and the sock filter was getting encrusted in rust pulled to it by the fuel pump. It would sit a bit and then the rust would settle and it would run again, but not for long. Stick a magnet in your tank and see if anything comes out. Good luck.
ne14914 |
Jun 18 2003, 07:17 PM
QUOTE(Jeffs74~914 @ Jun 18 2003, 03:54 PM) Does it cut off after running for a while or what? By "cutting off" does that mean it dies? If I am driving at 40mph it spudder like it needs more fuel. And then when I come to a light, it starts to shut down, I will have to give it more gas for it to stay started. If not it will cut off. When i try to turn it over, it just spin, as if our of gas - then it starts. I feel that eventually, it wont cut back on. Does that sound like the fuel pump? How can I test it? |
StratPlayer |
Jun 18 2003, 08:51 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I had the same problem not to long ago, car wouldn't run, would start up but would not stay running,, it turned of to be a bad relay to the fuel pump,, check your relay in the relay box.
Curvie Roadlover |
Jun 18 2003, 09:46 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
Another thing you may want to try is the fuses on the relay board for the fuel pump Check and clean the contacts. This was what sidelined me on the first day of ownership of my current car. I had no idea why it was cutting out. I was rescued (over the phone) by someone who knows these cars quite well (thanks again, Brad). He said, "Roll the fuses in their holders. They tend to get corroded and cause fuel pump to cut off". I did that and haven't had a problem since.
ne14914 |
Jun 18 2003, 09:51 PM
keep the suggestions coming -
I am going to start working on it tomorrow morning. Hopefully some of you - wont be at work (IMG:style_emoticons/default/biggrin.gif) if i have questions (IMG:style_emoticons/default/confused24.gif) Thanks guys ... |
Jeffs9146 |
Jun 19 2003, 12:14 AM
I think its the head temp sensor! or the fuel pressure regulator. Is it a 2.0 with fi?
Jeff |
Lo-Fi Version | Time is now: 10th May 2024 - 12:34 PM |
