Mirror Glass, Replacement glass for mirror |
jdm914 |
May 3 2016, 04:56 AM
Member Group: Members Posts: 54 Joined: 27-April 05 From: Charleston, WV Member No.: 3,992 Region Association: South East States |
Does any one sell replacement glass for OEM 914 mirrors? My local glass shop can not get the proper thickness for cutting. I have several mirrors that need the glass replaced.
May 3 2016, 05:27 AM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm waiting for 914rubber to have it ready.
Tbrown4x4 |
May 3 2016, 06:17 AM
Senior Member Group: Members Posts: 699 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
The side mirrors or the center mirror?
jdm914 |
May 3 2016, 06:32 AM
Side mirror...
rgalla9146 |
May 3 2016, 07:20 AM
Advanced Member Group: Members Posts: 4,538 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Kansas 914 |
May 3 2016, 09:09 AM
Cuda911 |
May 3 2016, 09:46 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Side mirror... I think some here have just gone to a local glass/mirror company and had them cut for about $5. I had new mirrors made at a local glass shop. They had no problem at all, but I think it was about $50 for the pair, since they had to do quite a bit of sanding or grinding to get a perfect fit. Anyway, the results were great! Old and new: Attached image(s) |
RohJay |
May 3 2016, 01:36 PM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
Does any one sell replacement glass for OEM 914 mirrors? My local glass shop can not get the proper thickness for cutting. I have several mirrors that need the glass replaced. There are several for sale on eBay.de. This is one listing |
914Sixer |
May 3 2016, 02:22 PM
914 Guru Group: Members Posts: 8,845 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Sierra Madre Collection and AA has them, BUT they are thinner than the factory glass. The glass is laser cut and a perfect fit but they will need a little spacing help on the back side.
jdm914 |
May 17 2016, 08:48 AM
I ordered one from Auto Atlanta but it was not a perfect fit. I am sending it back and still looking.
tomrev |
May 17 2016, 01:52 PM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
Just did this at my local glass place; took cracked, old mirror for templant. Fresh mirror was $6. Pretty effortless!
Kansas 914 |
May 17 2016, 03:10 PM
Just did this at my local glass place; took cracked, old mirror for templant. Fresh mirror was $6. Pretty effortless! (IMG:style_emoticons/default/agree.gif) |
914Sixer |
May 17 2016, 03:41 PM
You do know there is TWO different size mirrors ?
Kansas 914 |
May 17 2016, 04:43 PM
jdm914 |
May 18 2016, 04:52 AM
What is the correct thickness for the side mirror? The one I removed was 2.75mm and the one I bought was 2.25mm. The finish and diameter cut was perfect from AA but the thickness I'm not sure of. AA said I could return it and were easy to deal with or I could add a spacer and use it but I would rather pay more and have a perfect fit if possible. Am I asking to much?
jdm914 |
May 19 2016, 04:45 AM
I went ahead and kept the mirror and added a medium density 3/16" thick padding to the back of the mirror to get a proper fit. I usually do not like to modify parts to get a fit but in this case I made an exception. All is good again, at least for now....
Mikey914 |
May 19 2016, 10:40 AM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
There are 2 different sizes, we have cut some with the water jet, but the material wants to move as it started to float toward the end. Makes it come in a little more than it should. We just need to tweek the program to cut larger and will have to polish the edges.
Lo-Fi Version | Time is now: 29th March 2024 - 02:52 AM |
