Alternator removal - engine out of car, Least disruptive method |
jack20 |
May 3 2016, 10:02 AM
Member Group: Members Posts: 404 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Hi All,
Engine is 99% for reinstallation. All tins, heat exchangers, heat pipes, etc are installed. I'd like to remove and replace the alternator. I know, should have thought of this before... Haynes manual has an R&R process that assumes engine is installed in the car. What is the minimum of surrounding parts that I will need to remove to get the alternator? Thanks in advance. Jack |
iankarr |
May 3 2016, 10:07 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,469 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Not bad at all. Maybe 15 minutes of disassembly. If memory serves...Front tin, left side tin, fan housing (I think only the front half). It's pretty obvious one you start.
May 3 2016, 10:28 AM
Custom Member Group: Members Posts: 24,501 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Jtube underneath alternator needs to be removed.
Then, remove alternator from below, as designed. |
jack20 |
May 3 2016, 12:05 PM
Thanks guys. Here is the way it worked for me in case anyone searches for this in the future. Removed J tube and heater valve along with the pipe it's attached to.
Removed front tin. Removed alternator bolt on bottom. Removed top hex bolt. Pulled alternator and its tin out from front. Jack |
Lo-Fi Version | Time is now: 29th March 2024 - 04:39 AM |
