Brake lights when shifting, When I shift... |
GreatPumpkin |
May 3 2016, 12:34 PM
Member Group: Members Posts: 122 Joined: 28-October 07 From: Centerville OHIO Member No.: 8,272 Region Association: None |
Someone I work with told me today that everytime I shift my car my brake lights come on . I just replaced my clutch two weeks ago so I'm thinking I messed something up . I haven't really had time to look at it yet since I'm at work til later , but any suggestions on what to check first ? Haha it's always something isn't it ?
AZ914 |
May 3 2016, 01:45 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
The clutch is on the left. Just kidding.. did you replace the clutch cable? If so, I'd guess its caught up on the switch area as well.
Darren C |
May 3 2016, 01:50 PM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
The clutch is on the left. Just kidding.. did you replace the clutch cable? If so, I'd guess its caught up on the switch area as well. The clutch cable is no where near the switch and cannot get "caught up" on the switch or its wires. Lift the mat, remove the two allen socket head bolts, pedal rubbers and accelerator pedal, lift out the cover plate and take a look at what's happening to the switch while you press the clutch pedal up and down. |
rgalla9146 |
May 3 2016, 02:02 PM
Advanced Member Group: Members Posts: 4,557 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The clutch is on the left. Just kidding.. did you replace the clutch cable? If so, I'd guess its caught up on the switch area as well. The clutch cable is no where near the switch and cannot get "caught up" on the switch or its wires. Lift the mat, remove the two allen socket head bolts, pedal rubbers and accelerator pedal, lift out the cover plate and take a look at what's happening to the switch while you press the clutch pedal up and down. I second that, my guess is that when you push the clutch pedal the brake pedal is moving down as well. Cluster bushings ? or loose or maladjusted brake light switch. |
Lo-Fi Version | Time is now: 19th May 2024 - 05:13 PM |
