Brake lights when shifting, When I shift... |
GreatPumpkin |
May 3 2016, 12:34 PM
Member Group: Members Posts: 122 Joined: 28-October 07 From: Centerville OHIO Member No.: 8,272 Region Association: None |
Someone I work with told me today that everytime I shift my car my brake lights come on . I just replaced my clutch two weeks ago so I'm thinking I messed something up . I haven't really had time to look at it yet since I'm at work til later , but any suggestions on what to check first ? Haha it's always something isn't it ?
GreatPumpkin |
May 3 2016, 02:46 PM
Update : the switch may have been loose ? I took the pedal board off and felt back behind the brake pedal and tightend something as much as I could with my fingers and no more brake lights . Thank you guys
Darren C |
May 4 2016, 07:35 AM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
Update : the switch may have been loose ? I took the pedal board off and felt back behind the brake pedal and tightend something as much as I could with my fingers and no more brake lights . Thank you guys Now were all wondering "what" you tightened up with your fingers???? The switch is held in place with two small screws, not easy at all to "tighten with fingers" The only thing that you could get your fingers around easily is the rod from pedal to master cylinder adjusting nut in which case you have bigger issues now. From your description of "something" and your general demeanour, I'd guess you didn't lift out the pedal cover board once you took the socket head bolts out, as its a bit of a Rubik Challenge, and you've been working blind??? |
Lo-Fi Version | Time is now: 19th May 2024 - 04:14 PM |
