WTB, handful of little things..., Now I just need the cooling flaps w/ rod, thanks! |
RoadGlue |
May 3 2016, 02:03 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Hi all,
Here's some of what I need to start to wrap up this phase of my 914 project: - Flaps w/ connecting rod for cooling shroud Hmm, think that's it! I'm in N. California, 95401 Thanks in advance, Randy |
matthepcat |
May 3 2016, 02:52 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
If you don't care about originality you can get the lic plate bracket clips from any auto parts store, also often Ace Hardware or Orchard Supply hardware. (Home Depot doesn't have them, I checked yesterday)
Hi all, Here's some of what I need to start to wrap up this phase of my 914 project: - Uncracked alternator to cooling shroud rubber duct/hose - The two clips that hold the license plate bracket to the rear bumper. I'll buy the bracket too if you want to sell it as a set - Bumper tow hook block-off cap - Flaps w/ connecting rod for cooling shroud Hmm, think that's it! I'm in N. California, 95401 Thanks in advance, Randy |
RoadGlue |
May 3 2016, 02:54 PM
If you don't care about originality you can get the lic plate bracket clips from any auto parts store, also often Ace Hardware or Orchard Supply hardware. (Home Depot doesn't have them, I checked yesterday) Thanks! Scratch that from my list them. (IMG:style_emoticons/default/smile.gif) |
gcrotvik |
May 3 2016, 03:14 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Hi all, Here's some of what I need to start to wrap up this phase of my 914 project: - Uncracked alternator to cooling shroud rubber duct/hose - Bumper tow hook block-off cap - Flaps w/ connecting rod for cooling shroud Hmm, think that's it! I'm in N. California, 95401 Thanks in advance, Randy Hi Randy, I believe I have a set of flaps with connecting rod. I will look tonight and let you know. Greg |
RoadGlue |
May 3 2016, 03:21 PM
Hi Randy, I believe I have a set of flaps with connecting rod. I will look tonight and let you know. Greg (IMG:style_emoticons/default/beerchug.gif) Thank you! |
TheCabinetmaker |
May 3 2016, 04:45 PM
Alternator cooling boot available at Bughaus new for under ten bucks
malcolm2 |
May 3 2016, 05:55 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Got my tow ring plug at ACE hardware.
RoadGlue |
May 3 2016, 05:56 PM
You guys are awesome!
stinkindiesel |
May 4 2016, 11:54 AM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
Alternator cooling boot available at Bughaus new for under ten bucks I recently picked up one of these. Rubber boot is good, but the clamp that comes with it is just a standard hose clamp bent into a D shape. I found the original clamp fit much better, so I just reused it instead. Gary |
RoadGlue |
May 4 2016, 12:07 PM
Alternator cooling boot available at Bughaus new for under ten bucks I recently picked up one of these. Rubber boot is good, but the clamp that comes with it is just a standard hose clamp bent into a D shape. I found the original clamp fit much better, so I just reused it instead. Gary Good to know! I still have my cracked OEM boot, so I'll use that. Ended up ordering from AirHeadParts.com as it was a bit cheaper there and shipping was more reasonable as well. Cheers, Randy |
Lo-Fi Version | Time is now: 26th April 2024 - 12:10 AM |
