Engine is in ... Next question |
Amphicar770 |
May 4 2016, 07:38 PM
Senior Member Group: Members Posts: 1,189 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
A big milestone, engine and tranny are back in car. (IMG:style_emoticons/default/beerchug.gif) Thanks to all who have helped me get this far.
I have reconnected clutch cable before anything else as I want to make sure this whole thing with the arm is correct. I now have 3/4 -1" play when pulling pedal up. I think there is still enough slack in cable that excess pressure is not on TOB. When pedal fully depressed to floor there is about 3/8" (rough measure) remaining before arm would hit the trans case. Here is pic of cable end. Does everything sound like it is within spec? Thx |
Amphicar770 |
May 6 2016, 09:23 PM
Quiz question and real question,
Quiz: If you look closely at the engine picture there is a problem I had to correct before proceeding further. What is it? Actual question: After installing shift rod (I also have new Tangerine Shift Rod bearing and did grind down the coupler for clearance) I am unable to hit 4th or 5th gear. I am thinking this is a shift linkage adjustment issue? I can hit the other gears. Thx. |
Lo-Fi Version | Time is now: 14th May 2024 - 02:21 AM |
