Engine is in ... Next question |
Amphicar770 |
May 4 2016, 07:38 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
A big milestone, engine and tranny are back in car. (IMG:style_emoticons/default/beerchug.gif) Thanks to all who have helped me get this far.
I have reconnected clutch cable before anything else as I want to make sure this whole thing with the arm is correct. I now have 3/4 -1" play when pulling pedal up. I think there is still enough slack in cable that excess pressure is not on TOB. When pedal fully depressed to floor there is about 3/8" (rough measure) remaining before arm would hit the trans case. Here is pic of cable end. Does everything sound like it is within spec? Thx |
r_towle |
May 8 2016, 08:22 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Is it running yet?
Amphicar770 |
May 8 2016, 09:27 PM
Is it running yet? Darn close but not there yet. Went to put muffler on today and discovered PP sent wrong gaskets. I need to: bleed brakes and set the clearance in rear. Hook up fuel lines in rear, put fuel in tank. Attach muffler. Fire her up. Even though I ran new lines for fuel tank the 3 port pump is still up front. I dread pulling tank again but may replace pump with two port version while tank is empty before I start her. |
Lo-Fi Version | Time is now: 13th May 2024 - 04:09 PM |
