Engine is in ... Next question |
Amphicar770 |
May 4 2016, 07:38 PM
Senior Member Group: Members Posts: 1,189 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
A big milestone, engine and tranny are back in car. (IMG:style_emoticons/default/beerchug.gif) Thanks to all who have helped me get this far.
I have reconnected clutch cable before anything else as I want to make sure this whole thing with the arm is correct. I now have 3/4 -1" play when pulling pedal up. I think there is still enough slack in cable that excess pressure is not on TOB. When pedal fully depressed to floor there is about 3/8" (rough measure) remaining before arm would hit the trans case. Here is pic of cable end. Does everything sound like it is within spec? Thx |
Amphicar770 |
May 19 2016, 07:46 PM
If I connect a multimeter to the pins of the injector connectors that are not doing anything when pulled, should I see voltage pulses? That would at least tell me that signal is reaching the injectors???
I suppose that once I know there is spark at the plugs and signal to the injectors it narrows things down to: 1) Bad injector (maybe damaged when shop crimped the hoses on there?? Although that seems unlikely) 2) Something with valve adjustment, rockers, or related. If number 2 I am still thinking I will leave it to Porsche mechanic to fix. If I screwed it up with engine out of car I would probably do even worse with engine in!! |
malcolm2 |
May 20 2016, 11:21 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
If I connect a multimeter to the pins of the injector connectors that are not doing anything when pulled, should I see voltage pulses? That would at least tell me that signal is reaching the injectors??? I suppose that once I know there is spark at the plugs and signal to the injectors it narrows things down to: 1) Bad injector (maybe damaged when shop crimped the hoses on there?? Although that seems unlikely) 2) Something with valve adjustment, rockers, or related. If number 2 I am still thinking I will leave it to Porsche mechanic to fix. If I screwed it up with engine out of car I would probably do even worse with engine in!! I have been in your shoes a few times with my build. You will get it fixed and the World will not let you forget it. (IMG:style_emoticons/default/av-943.gif) Don't take the car somewhere, you are going to get it. I have L-jet and recently tested the injector spray pattern and for leaks. They all worked, but the procedure was critical. A voltmeter is not going to show pulses, the pulses are too fast. If you want to check pulses, you can go to a parts store that rents tools. You need NOID Lights. They will flicker. They are easy to use. But if you are checking the spray pattern, you don't need noid lights. The spray will tell you they work. Keep at it. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 04:21 AM |
