Engine is in ... Next question |
Amphicar770 |
May 4 2016, 07:38 PM
Senior Member Group: Members Posts: 1,189 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
A big milestone, engine and tranny are back in car. (IMG:style_emoticons/default/beerchug.gif) Thanks to all who have helped me get this far.
I have reconnected clutch cable before anything else as I want to make sure this whole thing with the arm is correct. I now have 3/4 -1" play when pulling pedal up. I think there is still enough slack in cable that excess pressure is not on TOB. When pedal fully depressed to floor there is about 3/8" (rough measure) remaining before arm would hit the trans case. Here is pic of cable end. Does everything sound like it is within spec? Thx |
r_towle |
May 20 2016, 12:33 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Listen to your video, listen to others online
I believe I can hear a loud racket in the cylinder that is not firing. If it was me, or I was nearby, I would pull the plugs and see which cylinder is not right. Post pics of the plugs if you have questions. |
Amphicar770 |
May 20 2016, 05:12 PM
Listen to your video, listen to others online I believe I can hear a loud racket in the cylinder that is not firing. If it was me, or I was nearby, I would pull the plugs and see which cylinder is not right. Post pics of the plugs if you have questions. Pulled plug #2 since that is one of them where pulling injector plug makes no diff. It does spark. It looks like a brand new plug (which it is). |
Lo-Fi Version | Time is now: 13th May 2024 - 09:25 PM |
