Engine is in ... Next question |
Amphicar770 |
May 4 2016, 07:38 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
A big milestone, engine and tranny are back in car. (IMG:style_emoticons/default/beerchug.gif) Thanks to all who have helped me get this far.
I have reconnected clutch cable before anything else as I want to make sure this whole thing with the arm is correct. I now have 3/4 -1" play when pulling pedal up. I think there is still enough slack in cable that excess pressure is not on TOB. When pedal fully depressed to floor there is about 3/8" (rough measure) remaining before arm would hit the trans case. Here is pic of cable end. Does everything sound like it is within spec? Thx |
Amphicar770 |
May 21 2016, 03:44 PM
I will both kick myself and celebrate if this is the case.
Just tested w/ noid light and all work. So, started looking at "how to adjust valve" threads again when I saw this picture. Is this right? If so, there is a good possibility that I have 2 & 3 switched on the distributor. |
Lo-Fi Version | Time is now: 13th May 2024 - 04:23 PM |
