Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
We had a very nice drive getting to Ridgway. The town has a nice head shop, and a good supply in the smoke shops. (IMG:style_emoticons/default/smoke.gif) Time to relax. Jerrry Welcome to Colorado - a state with benefits..... |
green914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California ![]() |
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
I'm a happy guy! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smoke.gif) |
JustinMeier |
Member ![]() ![]() Group: Members Posts: 244 Joined: 3-August 16 From: Scottsdale Member No.: 20,258 Region Association: None ![]() |
Justin, I never met your dad, from what I have read, I missed out on knowing a really great guy. Look forward to meeting you. (IMG:style_emoticons/default/beerchug.gif) Everyone have a safe trip! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving-girl.gif) We had a very nice drive getting to Ridgway. The town has a nice head shop, and a good supply in the smoke shops. (IMG:style_emoticons/default/smoke.gif) Time to relax. (IMG:style_emoticons/default/bye1.gif) Jerrry Same here! Everyone should stop at LivWell and use my rewards card # (IMG:style_emoticons/default/wink.gif) |
green914 |
What time is everyone leaving Ray's to head for Moab? (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving.gif)
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
1:30ish-ish??
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,119 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Hope you get it up and running would be great to see you caravan with us to Ridgeway. Good Luck (IMG:style_emoticons/default/driving-girl.gif) Thanks, Fighting this one till the end and I still hope to make it. I probably wont finish everything I wanted to get done but did manage to address the problems that came up. Got the d-jet working again. My MPS had decided it no longer wanted to hold vacuum. also found the harness side connector for my head temp sensor was just about broken off. Fixed both issues but my spare MPS is less than perfect (slight leak). going to see if I can borrow one from another local guy so I have a spare for the trip. I think we have Bronze bushings here... I had a set of bronze ones on my shelf, back in the car and good to go. Scott had a spare unmolested 049 MPS from his no longer used 1.7 that I am borrowing for the weekend. I my only 1.7 spare was an 041 that looks to have been rebuilt, works but is noticeably lean under light throttle, the 049 is nice and smooth so ill drive on that one and bring the 041 as my backup given both of them seem to have very minor leaks. As it stands right now im looking good to go. |
mgp4591 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,747 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region ![]() ![]() |
Hope you get it up and running would be great to see you caravan with us to Ridgeway. Good Luck (IMG:style_emoticons/default/driving-girl.gif) Thanks, Fighting this one till the end and I still hope to make it. I probably wont finish everything I wanted to get done but did manage to address the problems that came up. Got the d-jet working again. My MPS had decided it no longer wanted to hold vacuum. also found the harness side connector for my head temp sensor was just about broken off. Fixed both issues but my spare MPS is less than perfect (slight leak). going to see if I can borrow one from another local guy so I have a spare for the trip. I think we have Bronze bushings here... I had a set of bronze ones on my shelf, back in the car and good to go. Scott had a spare unmolested 049 MPS from his no longer used 1.7 that I am borrowing for the weekend. I my only 1.7 spare was an 041 that looks to have been rebuilt, works but is noticeably lean under light throttle, the 049 is nice and smooth so ill drive on that one and bring the 041 as my backup given both of them seem to have very minor leaks. As it stands right now im looking good to go. So we're seeing you at PMB at 8:30 or so? (IMG:style_emoticons/default/shades.gif) |
StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,339 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
thats great, we are meeting at pmb at 8 30 am. see you there.
JamesM |
Hope you get it up and running would be great to see you caravan with us to Ridgeway. Good Luck (IMG:style_emoticons/default/driving-girl.gif) Thanks, Fighting this one till the end and I still hope to make it. I probably wont finish everything I wanted to get done but did manage to address the problems that came up. Got the d-jet working again. My MPS had decided it no longer wanted to hold vacuum. also found the harness side connector for my head temp sensor was just about broken off. Fixed both issues but my spare MPS is less than perfect (slight leak). going to see if I can borrow one from another local guy so I have a spare for the trip. I think we have Bronze bushings here... I had a set of bronze ones on my shelf, back in the car and good to go. Scott had a spare unmolested 049 MPS from his no longer used 1.7 that I am borrowing for the weekend. I my only 1.7 spare was an 041 that looks to have been rebuilt, works but is noticeably lean under light throttle, the 049 is nice and smooth so ill drive on that one and bring the 041 as my backup given both of them seem to have very minor leaks. As it stands right now im looking good to go. So we're seeing you at PMB at 8:30 or so? (IMG:style_emoticons/default/shades.gif) 8:30 is about 2 hours before I usually open my eyes in the morning, but yes, going to try and be there. Packing the car and getting the coffee machine ready now. |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Made it to SLC. Much closer now
JustinMeier |
I made it to So Cal, much further now. (IMG:style_emoticons/default/laugh.gif)
Kansas 914 |
Sharon,
I noticed the lunch time on Friday at Bent Elbow was 12:30. If you leave Ridgway at 10:00am it is a one hour drive (34 miles) to Silverton. That puts you there at 11:00am. Is lunch at 12:30 firm? The reason I am asking is to coordinate my departure with Jim from Durango. Thanks! |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
I LOVE Mike's "WWSD" slogan.
We need shirts with that on it. |
Kansas 914 |
I LOVE Mike's "WWSD" slogan. We need shirts with that on it. (IMG:style_emoticons/default/smile.gif) I don't think too many people understood it - glad you did - cheers! Sorry you won't be here this weekend. |
Larmo63 |
I'll be there in spirit!!!!!!
JustinMeier |
Sharon, I noticed the lunch time on Friday at Bent Elbow was 12:30. If you leave Ridgway at 10:00am it is a one hour drive (34 miles) to Silverton. That puts you there at 11:00am. Is lunch at 12:30 firm? The reason I am asking is to coordinate my departure with Jim from Durango. Thanks! I'm possibly interested in joining the caravan.. I'm in Cortez tonight, I was going to go up 145 but I could modify that and do 550. When were you guys planning on leaving? |
Kansas 914 |
Sharon, I noticed the lunch time on Friday at Bent Elbow was 12:30. If you leave Ridgway at 10:00am it is a one hour drive (34 miles) to Silverton. That puts you there at 11:00am. Is lunch at 12:30 firm? The reason I am asking is to coordinate my departure with Jim from Durango. Thanks! I'm possibly interested in joining the caravan.. I'm in Cortez tonight, I was going to go up 145 but I could modify that and do 550. When were you guys planning on leaving? Justin - we are still trying to figure that out. We just want to arrive in Silverton by lunch and meet the gang there. I love that drive along 145. |
JustinMeier |
Justin - we are still trying to figure that out. We just want to arrive in Silverton by lunch and meet the gang there. I love that drive along 145. Looking at the map, it looks like 550 is my only real choice. Let me know what you come up with and I'll try to make it. |
Kansas 914 |
Justin - we are still trying to figure that out. We just want to arrive in Silverton by lunch and meet the gang there. I love that drive along 145. Looking at the map, it looks like 550 is my only real choice. Let me know what you come up with and I'll try to make it. Do you want to meet the group in Ridgway and make the drive to Silverton with them and hang out in town before lunch? |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,855 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Great weather, gonna be top-off driving weather; got sunscreen ?
Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 21st August 2025 - 11:58 AM |
