Rear Trailing Arms, Reinforcements to Resist Twisting |
Heater Guy |
May 6 2016, 10:00 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Lamont Welding & Fabrication in Antioch, CA (925) 754-7824 has a fixture to modify trailing arms. It holds the trailing arm in the correct stock alignment.
He mounts the trailing arm in the fixture, cuts it in half and welds in a 1/8" rectangular plate. The 1/8" plate helps to reduce twisting deformation by breaking the twisting length of the arm into two lengths instead of one long length. The charge is $80.00 per trailing arm. I just had my trailing arms reinforced. This reinforcing method is better than plating the arms with heavy sheet metal. |
ChrisFoley |
May 7 2016, 09:48 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This reinforcing method is better than plating the arms with heavy sheet metal. Welding a bulkhead inside the trailing arm box is the most effective stiffening method IMO. Lighter than boxed, and no warpage. Stiffer than drilling and welding tubes thru. An added advantage is the fixturing - assures proper orientation of the T/A. I've been doing it this way for many years. |
Randal |
May 7 2016, 10:29 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
This reinforcing method is better than plating the arms with heavy sheet metal. Welding a bulkhead inside the trailing arm box is the most effective stiffening method IMO. Lighter than boxed, and no warpage. Stiffer than drilling and welding tubes thru. An added advantage is the fixturing - assures proper orientation of the T/A. I've been doing it this way for many years. And when you get done installing Chris's reinforced trailing arms the car aligns correctly, unless of course you have a bent body. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:22 AM |
