Rear Trailing Arms, Reinforcements to Resist Twisting |
Heater Guy |
May 6 2016, 10:00 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Lamont Welding & Fabrication in Antioch, CA (925) 754-7824 has a fixture to modify trailing arms. It holds the trailing arm in the correct stock alignment.
He mounts the trailing arm in the fixture, cuts it in half and welds in a 1/8" rectangular plate. The 1/8" plate helps to reduce twisting deformation by breaking the twisting length of the arm into two lengths instead of one long length. The charge is $80.00 per trailing arm. I just had my trailing arms reinforced. This reinforcing method is better than plating the arms with heavy sheet metal. |
J P Stein |
May 11 2016, 07:20 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
A bit of drift on the trailing arm, but we are still in the area.
I march to the beat of my own drummer. Sure I listen (or read) what other folks are doing to their cars and take interest in how /what they are dealing with problems. Some times I even say "hay, that is pretty slick"......some times NOT. News Flash!!! Failure of the trailing arm mount is a larger problem than the arm itself and effects all, not just racers. Marching to my drummer.... Looks pretty simple, no?. It ain't. There is a 3/16 piece of plate replacing the inner half of the mount. The reinforcement tube goes to the frame and not the skimpy fwd bulkhead for a reason. No, not a perfect fix, but that ain't going anywhere. I think I have detailed pictures of the process if you want em'.....but it will cost you a PM. |
Lo-Fi Version | Time is now: 20th May 2024 - 08:22 AM |
