Rear Trailing Arms, Reinforcements to Resist Twisting |
Heater Guy |
May 6 2016, 10:00 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Lamont Welding & Fabrication in Antioch, CA (925) 754-7824 has a fixture to modify trailing arms. It holds the trailing arm in the correct stock alignment.
He mounts the trailing arm in the fixture, cuts it in half and welds in a 1/8" rectangular plate. The 1/8" plate helps to reduce twisting deformation by breaking the twisting length of the arm into two lengths instead of one long length. The charge is $80.00 per trailing arm. I just had my trailing arms reinforced. This reinforcing method is better than plating the arms with heavy sheet metal. |
J P Stein |
May 8 2016, 07:27 AM
I dunno........
I built my 914 AXer over a period of 15 years. I started off with a rust free 74 (or as close as it gets) stocker. It ended up with 10 inch slicks and having been gone through from end to end. It got an alignment check every year as I jumped around for set ups but it was stable for the last few years as far as modifications went....it still got the alignment checked. The car was light & worked out well. Other than seam welding, needle bearings, some grinding for lightness & 275 lb rear springs, the trailing arms were untouched and never a problem. I was never one to leave a real "problem" alone but a believer in "if it ain't broke...." |
Lo-Fi Version | Time is now: 9th May 2024 - 06:08 PM |
