Rear Trailing Arms, Reinforcements to Resist Twisting |
Heater Guy |
May 6 2016, 10:00 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Lamont Welding & Fabrication in Antioch, CA (925) 754-7824 has a fixture to modify trailing arms. It holds the trailing arm in the correct stock alignment.
He mounts the trailing arm in the fixture, cuts it in half and welds in a 1/8" rectangular plate. The 1/8" plate helps to reduce twisting deformation by breaking the twisting length of the arm into two lengths instead of one long length. The charge is $80.00 per trailing arm. I just had my trailing arms reinforced. This reinforcing method is better than plating the arms with heavy sheet metal. |
J P Stein |
May 8 2016, 10:48 AM
A cage/sub frame with the shock towers attached came to me later in the build...maybe 10 years into it. It's hard to explain to someone who's never done it, but it was the best move I ever made. The closest thing I could say was the car became a "piece".( which is meaningless to many)
Lo-Fi Version | Time is now: 9th May 2024 - 08:32 PM |
