Rear Trailing Arms, Reinforcements to Resist Twisting |
Heater Guy |
May 6 2016, 10:00 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Lamont Welding & Fabrication in Antioch, CA (925) 754-7824 has a fixture to modify trailing arms. It holds the trailing arm in the correct stock alignment.
He mounts the trailing arm in the fixture, cuts it in half and welds in a 1/8" rectangular plate. The 1/8" plate helps to reduce twisting deformation by breaking the twisting length of the arm into two lengths instead of one long length. The charge is $80.00 per trailing arm. I just had my trailing arms reinforced. This reinforcing method is better than plating the arms with heavy sheet metal. |
jhadler |
May 9 2016, 03:13 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
My recollection was that the trailing arm mounting ears were typically responsible for much of the flexing under load, and that reinforcing the arms themselves does not really stop that from happening... Reinforcing the mounting ears though...
-Josh |
ChrisFoley |
May 9 2016, 03:46 PM
I am Tangerine Racing Group: Members Posts: 7,924 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
My recollection was that the trailing arm mounting ears were typically responsible for much of the flexing under load, and that reinforcing the arms themselves does not really stop that from happening... Reinforcing the mounting ears though... -Josh Everything flexes if you put enough load on it. Stock arms definitely flex if you have wide sticky tires, as do the outer console brackets and even the inner and outer consoles on the longitudinals. These cars were not originally engineered to cope with 1+ lateral G force. |
Lo-Fi Version | Time is now: 10th May 2024 - 07:41 AM |
