Rear Trailing Arms, Reinforcements to Resist Twisting |
Heater Guy |
May 6 2016, 10:00 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Lamont Welding & Fabrication in Antioch, CA (925) 754-7824 has a fixture to modify trailing arms. It holds the trailing arm in the correct stock alignment.
He mounts the trailing arm in the fixture, cuts it in half and welds in a 1/8" rectangular plate. The 1/8" plate helps to reduce twisting deformation by breaking the twisting length of the arm into two lengths instead of one long length. The charge is $80.00 per trailing arm. I just had my trailing arms reinforced. This reinforcing method is better than plating the arms with heavy sheet metal. |
J P Stein |
May 10 2016, 08:07 AM
I found the most Gawd awful welding on the 914 Right at the mounting points area for the trailing arms. lit myself on fire while rewelding/grinding overhead....not my best position when welding, but after grinding most of that mess out of there , the reweld looked pretty good....... a separate issue from torque tube twist. I too would rather replace a torque tube IF something has to fail.
I have no doubts the tubes twist under load. . Mine never twisted enough to take a set, but since I couldn't feel it, it didn't happen. I'm a butt dyno kinda guy. Pick your own poison. |
Lo-Fi Version | Time is now: 10th May 2024 - 10:14 AM |
