Rear Trailing Arms, Reinforcements to Resist Twisting |
Heater Guy |
May 6 2016, 10:00 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Lamont Welding & Fabrication in Antioch, CA (925) 754-7824 has a fixture to modify trailing arms. It holds the trailing arm in the correct stock alignment.
He mounts the trailing arm in the fixture, cuts it in half and welds in a 1/8" rectangular plate. The 1/8" plate helps to reduce twisting deformation by breaking the twisting length of the arm into two lengths instead of one long length. The charge is $80.00 per trailing arm. I just had my trailing arms reinforced. This reinforcing method is better than plating the arms with heavy sheet metal. |
old914dog |
May 10 2016, 08:58 AM
Member Group: Members Posts: 72 Joined: 28-August 04 From: dallas,tx Member No.: 2,643 Region Association: None |
Brant and Chris,
Since Vintage racing does not allow "cage to suspension pick-up points," what is your opinion on the inner ear reinforcement which goes forward to the lower firewall. Can be welded or bolt-in as small radius rod. I also think the inner ear problems are partially due to the outer ear becoming loose or ?? Please opine for us vintage cars and more vintage drivers!! |
Lo-Fi Version | Time is now: 10th May 2024 - 11:52 AM |
