what does this mean |
Gunn1 |
May 13 2016, 08:02 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
914Sixer |
May 13 2016, 08:08 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Engine cylinder head number. Also stamped in the rocker arm assembly area. Quick reference for the person building type 4 motors.
r_towle |
May 13 2016, 08:09 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I am gonna say casting number, but check in underneath the valve cover there should be a visible number that would match that one.
Rich |
Gunn1 |
May 13 2016, 08:20 PM
Thanks guys
SirAndy |
May 13 2016, 08:51 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What size engine is that?
(IMG:style_emoticons/default/idea.gif) |
nathansnathan |
May 14 2016, 09:21 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I think when there is the blue stamping of part numbers on part numbers when there ususally isn't one on that part means it's part of an exchange program. The PET doesn't haver that exact part number, but the closest is for 021 101 061 which has another part number in the description, 022.101.372, "Cylinder Head exchanghe, with valves, D-Jetronic M W0 002 545 >> W0 129 581, cam follower protective lube, 31.7 mm 022.101.372 embedded" whatever that all means... 371 probably unlubricated version. (IMG:style_emoticons/default/wink.gif)
Gunn1 |
May 14 2016, 07:29 PM
Gunn1 |
May 14 2016, 07:59 PM
I think when there is the blue stamping of part numbers on part numbers when there ususally isn't one on that part means it's part of an exchange program. The PET doesn't haver that exact part number, but the closest is for 021 101 061 which has another part number in the description, 022.101.372, "Cylinder Head exchanghe, with valves, D-Jetronic M W0 002 545 >> W0 129 581, cam follower protective lube, 31.7 mm 022.101.372 embedded" whatever that all means... 371 probably unlubricated version. (IMG:style_emoticons/default/wink.gif) Excuse me but what does all that fancy lingo mean |
r_towle |
May 14 2016, 10:55 PM
He can read
Gunn1 |
May 15 2016, 01:05 AM
He can read He can read what? Now that we know we can all read (har, har, har) What is the lay mans version of PET, cylinder head exchange ( dealer or factory replAced?, modified?) Lubricated, non lubricated, with valves? It's apparent My cerebral cortex isn't as large as Richards is and am looking For a little more explanation. Thank you |
nathansnathan |
May 15 2016, 02:13 AM
PET is "Porsche Ersatz Teile Katalog" or "Porsche Parts Catalog".
http://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf Factory exchange program is like when a service place would get a replacement engine or just the replacement head. You'd get a whole blank serial motor, one that had both bus and 914 oil fill options and the service department would stamp your original engine numbers on it. They might have replaced just the head if the owner smoked the valved during warranty, or possibly during the 80's or 90's and dealt with a place that used factory parts. Later repairs would have been more likely to use aftermarket parts as those original factory replacement parts became nla. I'd be all over factory exchange heads or whole motor if you could get those still. The other stuff, "embedded" I'm not sure. Seems the replacement head came with a tube of lubricant for greasing up the lifters and pushrod ends. Also not really sure what is 37.1 mm, might be a reference number rather than a metric length? The W numbers I think are engine numbers; if you had an original engine with US issue djet within that range, that's the replacement head you'd order. OP is 1 number off which seems to have been superseded in this version of the PET. With valves, just that there is a part number for the head and for the valves individually but also for this replacement package. |
Gunn1 |
May 15 2016, 06:48 AM
PET is "Porsche Ersatz Teile Katalog" or "Porsche Parts Catalog". http://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf Factory exchange program is like when a service place would get a replacement engine or just the replacement head. You'd get a whole blank serial motor, one that had both bus and 914 oil fill options and the service department would stamp your original engine numbers on it. They might have replaced just the head if the owner smoked the valved during warranty, or possibly during the 80's or 90's and dealt with a place that used factory parts. Later repairs would have been more likely to use aftermarket parts as those original factory replacement parts became nla. I'd be all over factory exchange heads or whole motor if you could get those still. The other stuff, "embedded" I'm not sure. Seems the replacement head came with a tube of lubricant for greasing up the lifters and pushrod ends. Also not really sure what is 37.1 mm, might be a reference number rather than a metric length? The W numbers I think are engine numbers; if you had an original engine with US issue djet within that range, that's the replacement head you'd order. OP is 1 number off which seems to have been superseded in this version of the PET. With valves, just that there is a part number for the head and for the valves individually but also for this replacement package. Thank you for the explanation Nathan. I appreciate you taking the time to better "spell things out" for me. Thanks again |
Lo-Fi Version | Time is now: 9th May 2024 - 08:28 PM |
