back to that oil leak, Is the oil cooler moveable?? |
d914 |
Apr 2 2005, 06:05 PM
Can the oil cooler be moved alittle if some of the brakets and such are removed???
The oil stand top bolt( where the oil filter hooks up) is leaking . Can't get a socket to clear and a wrench is highly doubtful... If the cooler moved a bit... without doing other harm this would be good. The four again... |
Joe Ricard |
Apr 2 2005, 06:38 PM
Yes.
Joe Ricard |
Apr 2 2005, 06:41 PM
Hmm, read this a couple of times. I would leave the cooler alone. Sounds like you need to pull the filter off. I think you can get a 1/4" drive shallow socket up there. You need to make a new gasket from some Gasket paper that you can get from NAPA. next to thinest they got.
d914 |
Apr 2 2005, 06:59 PM
got the gasket, getting some thing on that nut is the case, already removed the filter..????
d914 |
Apr 2 2005, 07:15 PM
part of the nut is covered by the cooler. stud is real short as not to interfere with the cooler. Unless the cooler can move about a quarter in. I couldnt do this with the engine out!!
Lo-Fi Version | Time is now: 19th May 2024 - 05:30 PM |
