1972 914 |
1972 914 |
Zimmy |
May 15 2016, 07:00 PM
I'm new here ... Group: Members Posts: 0 Joined: 31-July 14 From: Canada Member No.: 17,712 Region Association: None |
1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500
michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. |
nwm5709 |
May 17 2016, 08:26 AM
Newbie Group: Members Posts: 29 Joined: 7-January 16 From: Raleigh, NC Member No.: 19,536 Region Association: South East States |
Where is the car located?
Zimmy |
May 17 2016, 08:41 AM
Pat Garvey |
May 24 2016, 06:43 PM
1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500 michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. OK, I'll be the asshat here. Why no VIN? Why no pics? Rules are rules. If they aren't enforced they aren't rules. Do we need Trump here? |
Zimmy |
May 25 2016, 10:05 AM
We've established the following guidelines to help make your sales/purchases as successful as possible!
- Please List WTB:, FS:, TRADE: etc (want to buy, for sale, and trade respectively) before your add title. - Please put a price in your ad and state how you would like payment. - If you'd like to bump your ads, feel free to do so every two days. - DO NOT MAKE YOUR ADS IN ALL CAPITAL LETTERS! It's considered rude. - All eBay ads belong in the eBay category. - Please consolidate your ads into one big lump... listings and pictures together in one thread. Please be considerate of other classified users!! Sorry I forgot how I wanted the payment transaction. I would like cash or certified bank draft. |
Series9 |
May 31 2016, 08:59 AM
Pat Garvey,
Rules are rules: Do not comment on people's ads unless you are interested in purchasing the item or vehicle and you are requesting further information from the seller. If you have personal issues with a seller, keep them as such... personal. If you think the ad is misleading, contact the seller and an Admin via private message. Any further abuse or violations of the site rules (name calling) will get you banned. |
Zimmy |
Jun 28 2016, 07:56 AM
Posted pictures to my facebook page.
https://www.facebook.com/media/set/?set=a.1...mp;l=9a45723307 1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500 michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. |
Jun 28 2016, 08:03 AM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500 michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. OK, I'll be the asshat here. Why no VIN? Why no pics? Rules are rules. If they aren't enforced they aren't rules. Do we need Trump here? Pat - looks like he followed all the rules. Pics and vin are not required to sell a car. I would add pics it does help sell. Pat, you should know better and give the guy a break. |
0396 |
Jun 28 2016, 08:20 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500 michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. OK, I'll be the asshat here. Why no VIN? Why no pics? Rules are rules. If they aren't enforced they aren't rules. Do we need Trump here? Here's the rules / guidelines for your reference: Rules!, Return to the forum We've established the following guidelines to help make your sales/purchases as successful as possible! - Please List WTB:, FS:, TRADE: etc (want to buy, for sale, and trade respectively) before your add title. - Please put a price in your ad and state how you would like payment. - If you'd like to bump your ads, feel free to do so every two days. - DO NOT MAKE YOUR ADS IN ALL CAPITAL LETTERS! It's considered rude. - All eBay ads belong in the eBay category. - Please consolidate your ads into one big lump... listings and pictures together in one thread. Please be considerate of other classified users!! |
rwilner |
Jun 28 2016, 07:32 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
For anyone willing to follow that facebook link, there are tons of pics there...over 100.
Looks like an engine rebuild (carbs tho), completely restored brake calipers, refinished fuel tank. There's a riveted patch in the floor but I don't see much rust. Worth checking out if you're local and in the market. (I'm the latter, not the former) |
Larmo63 |
Jul 1 2016, 12:57 AM
Looks like a pretty good car for the money.
He did a lot of work on it. |
rick 918-S |
Jul 8 2016, 05:28 PM
Hey nice rack! -Celette Group: Members Posts: 20,417 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
For anyone willing to follow that facebook link, there are tons of pics there...over 100. Looks like an engine rebuild (carbs tho), completely restored brake calipers, refinished fuel tank. There's a riveted patch in the floor but I don't see much rust. Worth checking out if you're local and in the market. (I'm the latter, not the former) I hate face book. I can only see about 24 of the photos and there's a stupid sign up banner blocking the page like it's some big harry secret. |
Zimmy |
Jul 18 2016, 07:38 PM
Price update $8000.00 OBO
quote name='Zimmy' date='May 15 2016, 05:00 PM' post='2345154'] 1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500 michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. [/quote] |
Zimmy |
doherty224 |
Jul 19 2016, 11:43 AM
I'm new here ... Group: Members Posts: 0 Joined: 19-July 16 From: San Diego Member No.: 20,202 Region Association: Southern California |
Very nice looking, looks like a more than fair price to me. GLWS!
Zimmy |
Apr 12 2017, 06:48 PM
Hello,
Car is still for sale. This car need to be enjoyed by someone. Thanks for looking. Mike. |
Lo-Fi Version | Time is now: 23rd April 2024 - 11:45 PM |
