Any idea how to solve bad door clearence, longitudinal repared without stiffening |
914Gelb |
May 18 2016, 04:55 AM
Member Group: Members Posts: 90 Joined: 7-July 11 From: Vienna Member No.: 13,288 Region Association: Austria |
Hello Guys,
since many years I'm working on my 914-6 restoration project. Now I have finished most of the jobs like engine and transmission rebuild, electric harness, suspension ..., now it's time for the body work. Normally before I start I try to collect es much information to get a perfect result. My body was repaired in the past by unexperienced (IMG:style_emoticons/default/welder.gif) and now I have to fix this badly bodywork. See the pictures and look at the door clearence than you understand. The question is how can I fix this and if you had the same topic how was it fixed by you. Attached thumbnail(s) |
rgalla9146 |
May 18 2016, 08:21 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
It might not be as bad as you think.
I'd re-install the drive train and suspension and put the car on the ground. Roll the car around to settle it under its own weight. Do so with four uniform tires. On a flat floor. The issues can not be evaluated with the car on jackstands. The front gap will be done by "adjusting " the hinges with a floor jack or a big f_ _ _ _in hammer. Then the rear can be better judged. Remove the door latch until you get it close. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:03 PM |
