Any idea how to solve bad door clearence, longitudinal repared without stiffening |
914Gelb |
May 18 2016, 04:55 AM
Member Group: Members Posts: 90 Joined: 7-July 11 From: Vienna Member No.: 13,288 Region Association: Austria |
Hello Guys,
since many years I'm working on my 914-6 restoration project. Now I have finished most of the jobs like engine and transmission rebuild, electric harness, suspension ..., now it's time for the body work. Normally before I start I try to collect es much information to get a perfect result. My body was repaired in the past by unexperienced (IMG:style_emoticons/default/welder.gif) and now I have to fix this badly bodywork. See the pictures and look at the door clearence than you understand. The question is how can I fix this and if you had the same topic how was it fixed by you. Attached thumbnail(s) |
bretth |
Jun 21 2017, 07:46 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Maybe a previous owner was trying to improve tire to body clearance? I have similar dings on my car which I assume is where the larger tire was rubbing on the body.
Brett |
Lo-Fi Version | Time is now: 16th May 2024 - 09:01 PM |
