Any idea how to solve bad door clearence, longitudinal repared without stiffening |
914Gelb |
May 18 2016, 04:55 AM
Member Group: Members Posts: 90 Joined: 7-July 11 From: Vienna Member No.: 13,288 Region Association: Austria |
Hello Guys,
since many years I'm working on my 914-6 restoration project. Now I have finished most of the jobs like engine and transmission rebuild, electric harness, suspension ..., now it's time for the body work. Normally before I start I try to collect es much information to get a perfect result. My body was repaired in the past by unexperienced (IMG:style_emoticons/default/welder.gif) and now I have to fix this badly bodywork. See the pictures and look at the door clearence than you understand. The question is how can I fix this and if you had the same topic how was it fixed by you. Attached thumbnail(s) |
914Gelb |
Sep 27 2023, 07:14 AM
burton73 |
Sep 27 2023, 03:52 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
You are doing a super job on your 6 but I would like to make a suggestion, cut the pan and put the cover plates back the way it was from the factory. Your not hiding anything, and it looks like the pans where on the car as it came new. Just a small point. You can reuse your covers or get some used ones or you may find some new ones. That is what I did on my 6 Best Bob B |
Lo-Fi Version | Time is now: 16th May 2024 - 09:22 PM |
