Electronic Ignition, XR3000 |
meares |
Apr 3 2005, 03:26 PM
Member Group: Members Posts: 403 Joined: 23-March 05 From: Atlanta Member No.: 3,800 |
just bought a Crane XR 3000 Fireball Sys., LX 91 E Core Coil, with the locking coil wire, 5800 Rev. limiter, and finally distributor grease!!! it says not to use points....is this all i need to replace the stock system? to make it a point-less sys.? Also i'll get new plugs, any recommendations would be nice! Lastly, are the Magnacore K85 wires a good fit for what i'm doing? basically what i'm doing is replacing my 1.7 with a 2 and i think i'll get better performance with these upgrades..... Lots of questions so THANKS for answers in advance!!!
ArtechnikA |
Apr 3 2005, 04:08 PM
yes, which means you probably no longer have a need for the distributor grease. keep it as a souvenir - all the really good mechanics have a tube of that stuff tucked away in the back of a drawer somewhere ...
Bosch copper or silver-tipped 'C' or 'S' plugs work well; lots of guys like NKG's as well. Bosch fine-wire platinums don't work well, no matter how many electrodes they stick on 'em. the Magnecor's will be fine. |
Mueller |
the XR 3000 replaces the points inside the distributor if I am correct, so it sounds like you have everything you need.....I know with the Mallory stuff, the coil has to be a certain Ohm range to work properly, hopefully with the Crane stuff it is all matched to work together....
KenH |
Apr 3 2005, 04:11 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
Yes thats all you need.
I found installation of the shutter and distributer parts easier to install by removing the distributer. It takes a bit of time to place the bracket inside the distributor. Be sure the LED module clears everthing before you reinstall the distributer. If you use the Magnacore wires, which I recommend, I found the one for the 2.0 were way too long. I used the ones for the 1.7. I do not know why they make two different lenghts - neither did they when I asked. FYI - I mounted the module and coil in the trunk high up on the fire wall. Ken |
meares |
Apr 3 2005, 06:50 PM
thanks gents!!! should i use the stock distributor or buy a ( i'm fuzzy on the #s) Bosch 009 or 050? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Mueller |
Apr 3 2005, 06:54 PM
if using the stock D-Jet fuel injection, you must use the factory distributor.... if carbs or aftermarket Fuel injection, get a Mallory Unilite (of course you wouldn't need the Crane XR 3000 box) |
ArtechnikA |
Apr 4 2005, 05:29 AM
yes, you should use the stock distributor. |
p914 |
Apr 4 2005, 09:39 AM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
Check out the http://www.supersonicspark.com
and tell them your setup and they will suggest a proper plug, usually bosch or NGK. combined with the electronic ignition the plugs add the final touch. |
meares |
Apr 4 2005, 05:33 PM
BTW p914....GREAT pic beside your post!!!! is the stuff i bought REALLY worth it on a stock 2L?
ArtechnikA |
Apr 4 2005, 05:44 PM
if you mean, "will it release dozens of untapped HP" the answer is no. a really good CD ignition sometimes makes the car easier to start in the winter, idle a little better, and act a little crisper through the midrange. and you know you're not giving up anything on top. might be good for a couple of HP. if you mean "am i now relieved of having to d!ck with setting and replacing points forever" the answer is yes. some of us have time to 'commune' with the car, and i didn't begrudge it when i did, but my life has changed since those days ... |
p914 |
Apr 4 2005, 05:45 PM
Thanks I love Marylin (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif)
I think it is. I have a Jacobs I.C.E. Pak on my 2.0 75. I had a bit of a problem some time ago with a hiccup I could not get rid of. It had multiple problems that my mechanic was able to solve about 97%. The electronic ignition helped that out and overall made the car run smoother and get better milage. I then put in those plugs. There was a notable difference in the smooth running and milage as those plugs burn the gas in the chamber more efficiently. I talked with the folks at Supersonic and they made recommendations for colder running plugs as my Jacobs puts out 45-60K volts. I think that 914 fuel injectors are probably not the most efficient in spraying after a period of time so the plugs help atomize the fuel at the burn instead of having to rely on the injector making the proper spray. Just my 2 pennies worth. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:19 PM |
