turbo tie rods ends, has any used these |
mk114 |
Apr 3 2005, 07:36 PM
LOST in NO space (my garage) Group: Members Posts: 330 Joined: 29-March 05 From: Salt Lake Utah Member No.: 3,835 |
mk114 |
Apr 3 2005, 07:39 PM
URY914 |
Apr 3 2005, 07:40 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I bought mine at the cheapest supplier I could find.
I think there is only one supplier and he sells them to all the retail joints. |
Mueller |
Apr 3 2005, 07:45 PM
they are great if you need them (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
most people upgrade to these when the original units are in bad shape or when doing a total suspension upgrade to ensure everything is new...you might already have them if a PO installed them.... |
mk114 |
Apr 3 2005, 07:47 PM
oh i don't was getting ready to do it this week , my are original I'm sure
Series9 |
Apr 3 2005, 07:59 PM
They are one of the first things I do to a new-to-me 914.
Excellent upgrade. |
anthony |
Apr 3 2005, 08:07 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Make sure you get Lemforder brand turbo tie-rods. Not all turbo tie rod kits are top quality.
CptTripps |
Apr 3 2005, 08:14 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
First thing I bought...it'll be the last thing I put on the car after spending 4mos of restoration.
Grimstead |
Apr 3 2005, 08:30 PM
Cheaky Monkey Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California |
Is it me or do these seem a little high? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWA%3AIT |
anthony |
Apr 3 2005, 10:00 PM
Yeah, sounds high. I think Pelican wants $150.
ArtechnikA |
Apr 4 2005, 05:38 AM
i think they're still trying to find their price point ... day to go - no bids...
i have been TOLD that the Lemforder use castle nuts and the 'cheap ones' use the Nylock nut on the tie rod end. there's allegedly a longevity issue with the rubber boots as well. i seem to have been sold a set of 'the cheap ones' by AJ-USA but i'm going to run them and see how they do. |
Foxman |
Apr 4 2005, 06:31 AM
Member Group: Members Posts: 57 Joined: 17-March 05 From: Fort Worth, TX Member No.: 3,778 |
What does the car gain from the turbo tie rods? Thanks
ArtechnikA |
Apr 4 2005, 07:02 AM
the stock tie rods use a rubber bush to connect the inner end to the steering rack. the Turbo inner link uses a monoball. less compliance, slightly more precise and direct steering. it will also transmit a bit more road 'feel' to the driver which can be a great thing on the track or a bit tiring for a long-distance street car on marginal roads. it *should* be a final, icing-on-the-cake upgrade done after all the big issues are resolved - bad ball joints, worn and improperly adjusted front bearings, bad dampers, worn upper strut bearings... but probably 90% are installed because of worn tie rods that need to be replaced anyway, so it becomes a "for only a little more" upgrade. if you are very, very careful at matching rod lengths it shouldn't affect your toe, but it'd be a good idea to have the alignment at least checked by someone who knows how and with the appropriate equipment. |
nsyr |
Apr 4 2005, 07:17 AM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
www.eadparts.com has them for $95 for Lemfoerder.
Cano |
Apr 4 2005, 10:00 AM
Member Group: Members Posts: 110 Joined: 29-September 04 From: Goshen, KY Member No.: 2,854 Region Association: None |
The $95 eadparts.com "turbo tie rod kit" is only for ONE side of the vehicle-- one tie rod and a boot. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Have to buy two of these kits to get the entire kit that the bird has for $150.
Lo-Fi Version | Time is now: 17th May 2024 - 11:55 AM |
