WCR AX In-Car video from my run ... |
May 22 2016, 09:48 PM
Resident German Group: Admin Posts: 41,580 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Here's in-car video from my fastest afternoon run. Unfortunately, the camera is mounted a bit too low, i need to get an extension for the roll-bar mount to get it up higher.
The 1st lap was a 53.1 with the tires still somewhat cold and not gripping as well, the 2nd lap was a 51.2. I'm running on 10" GoodYear R250 slicks. (IMG:style_emoticons/default/driving.gif) https://www.youtube.com/watch?v=ZsOUzMKooVI |
Andyrew |
May 22 2016, 10:22 PM
Great Vid Andy!!
I'll put mine here when it uploads. Maybe we'll keep them all in one spot like the images? (IMG:style_emoticons/default/smile.gif) |
Bossman |
May 22 2016, 10:24 PM
Member Group: Members Posts: 67 Joined: 6-October 14 From: Red Bluff CA Member No.: 17,985 Region Association: Northern California |
wes |
May 23 2016, 12:33 AM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Excellent video thanks for sharing!
1stworks |
May 23 2016, 07:12 AM
Member Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None |
Nice,thanks for sharing.
EdwardBlume |
May 23 2016, 07:33 AM
Pretty cool. No chirping. Nice run.
76-914 |
May 23 2016, 07:35 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,455 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Cool. Not much shifting, was there? Did I hear something rubbing?
914werke |
May 23 2016, 07:37 AM
"I got blisters on me fingers" Group: Members Posts: 9,894 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
was it that one or the last that the battery jumped the tray?
JRust |
May 23 2016, 09:16 AM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Sweet Run Andy! You are one fast man. Great view really. I need to add a camera like that. Really changes your perspective. Interesting to see yourself as you are driving the coarse (IMG:style_emoticons/default/driving.gif)
6freak |
May 23 2016, 09:22 AM
COOL (IMG:style_emoticons/default/smile.gif)
dlkawashima |
May 23 2016, 10:44 AM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
May 23 2016, 11:12 AM
Did I hear something rubbing? was it that one or the last that the battery jumped the tray? Yes, if you listen closely you can hear a loud "thumb" right before i get on the main straight for the first time. That was my battery coming lose and laying on top of the engine for the rest of the run. (IMG:style_emoticons/default/wacko.gif) |
green914 |
May 23 2016, 12:24 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
cool! (IMG:style_emoticons/default/smilie_pokal.gif)
76-914 |
May 23 2016, 12:26 PM
Did I hear something rubbing? was it that one or the last that the battery jumped the tray? Yes, if you listen closely you can hear a loud "thumb" right before i get on the main straight for the first time. That was my battery coming lose and laying on top of the engine for the rest of the run. (IMG:style_emoticons/default/wacko.gif) Crap! OK, now tell us why it came loose so we can avoid a similar situation. Also, was there any collateral damage? |
May 23 2016, 12:40 PM
Crap! OK, now tell us why it came loose so we can avoid a similar situation. Also, was there any collateral damage? No damage. I have a redtop optima and i've been using their plastic holddown for years. It felt tight before the run and i did pass tech inspection (the guy did check the battery and it didn't move). It looks like that the mounting hole for the holddown is about 2mm off and the rounded edge doesn't sit flush against the battery. So all that is preventing it from moving is the clamping force between the front of the holddown and the battery base which apparently wasn't enough. (IMG:style_emoticons/default/idea.gif) Once the battery moves even just 2mm, it'll slide out of the back channel and is free to go wherever it wants to go. (IMG:style_emoticons/default/unsure.gif) |
Andyrew |
May 23 2016, 02:07 PM
Crap! OK, now tell us why it came loose so we can avoid a similar situation. Also, was there any collateral damage? No damage. I have a redtop optima and i've been using their plastic holddown for years. It felt tight before the run and i did pass tech inspection (the guy did check the battery and it didn't move). It looks like that the mounting hole for the holddown is about 2mm off and the rounded edge doesn't sit flush against the battery. So all that is preventing it from moving is the clamping force between the front of the holddown and the battery base which apparently wasn't enough. (IMG:style_emoticons/default/idea.gif) Once the battery moves even just 2mm, it'll slide out of the back channel and is free to go wherever it wants to go. (IMG:style_emoticons/default/unsure.gif) You know, I have actually had that happen now that you mention it. I put a piece of metal in front of the plastic hold down and held it in under the bolt to prevent the hold down from sliding. I think I used a small piece of wood in the beginning. |
May 23 2016, 02:14 PM
Custom Member Group: Members Posts: 24,499 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Every time you do that you must really smile knowing you did the right thing going to a 3.6 liter.
Justinp71 |
May 23 2016, 02:55 PM
Senior Member Group: Members Posts: 1,582 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Damn your car is fast off the line. Looks like an awesome venue... |
May 23 2016, 03:12 PM
914 Idiot Group: Members Posts: 14,974 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Once the battery moves even just 2mm, it'll slide out of the back channel and is free to go wherever it wants to go. (IMG:style_emoticons/default/unsure.gif) That's why I asked McMark to set up a hold-down across the top of the battery for me. I had made one myself, but it was a POS and a major pain to install/remove. --DD |
6freak |
May 23 2016, 03:32 PM
Here's in-car video from my fastest afternoon run. Unfortunately, the camera is mounted a bit too low, i need to get an extension for the roll-bar mount to get it up higher. The 1st lap was a 53.1 with the tires still somewhat cold and not gripping as well, the 2nd lap was a 51.2. I'm running on 10" GoodYear R250 slicks. (IMG:style_emoticons/default/driving.gif) https://www.youtube.com/watch?v=ZsOUzMKooVI thats it! im flaring my car and going with 12 inch race tires... (IMG:style_emoticons/default/av-943.gif) you wont beat me then...nice drive n bud MikeC |
Lo-Fi Version | Time is now: 28th March 2024 - 01:12 PM |
