GB- 914-6 plastic steering wheel cover at dash correct for 6, Another parts request I'm trying to fill |
Mikey914 |
Jan 27 2017, 10:45 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
On this run yes, they are not perfect.
As I mentioned I will be reworking the tool But it will not be a fast proposition. Figure 6-8 weeks for me to get this straightened out. I'll send you a set to play with MB911. Maybe we do some trading? WE can work that out via PM. But do drop me an adress again. Mark |
mb911 |
Jan 27 2017, 08:43 PM
914 Guru Group: Members Posts: 6,863 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
On this run yes, they are not perfect. As I mentioned I will be reworking the tool But it will not be a fast proposition. Figure 6-8 weeks for me to get this straightened out. I'll send you a set to play with MB911. Maybe we do some trading? WE can work that out via PM. But do drop me an adress again. Mark Sounds like a plan to me. |
Harpo |
Feb 19 2017, 09:54 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Mark please add me to the list for clamshells & eye brows.
Thanks David |
mb911 |
Feb 19 2017, 05:53 PM
I received Mark's samples and they look great. I need to spend some time playing around with them maybe this week.
larryM |
Feb 26 2017, 03:10 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
why?
- i recently got a repro pair from AA - $19.50 ea - 2 req'd |
Feb 26 2017, 04:05 PM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Biggles |
Apr 28 2017, 01:36 AM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Hi Mark
How's the tooling re-work coming along on these ? Chris |
brant |
May 2 2017, 10:56 AM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I'm going to need the eye brows too.
brant |
gcrotvik |
May 2 2017, 02:18 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
brant |
May 2 2017, 02:21 PM
gcrotvik |
Aug 25 2017, 07:56 AM
Just checking in on these. Mark, were you able to re-tool the clam shells? Is there an eta?
ConeDodger |
Aug 25 2017, 02:52 PM
Apex killer! Group: Members Posts: 23,602 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
When they're perfect. I'm in. No hurry.
mb911 |
Aug 25 2017, 03:18 PM
I will get back on this project shortly as I have a sample.. Been so busy with some many other projects but need to ramp this up..
Mikey914 |
Aug 27 2017, 10:15 AM
Just checking in on these. Mark, were you able to re-tool the clam shells? Is there an eta? We would be starting from scratch again on these, so I've put it off until I can get some other big projects completed. I literally have $15,000 into these to date and it's not making much sense to throw that into this again, at least at this time. I do have plenty of these that are close, and if you are making the column metal you can make them work, but not on a true 6. Sorry. |
Biggles |
Aug 27 2017, 11:27 AM
Just checking in on these. Mark, were you able to re-tool the clam shells? Is there an eta? We would be starting from scratch again on these, so I've put it off until I can get some other big projects completed. I literally have $15,000 into these to date and it's not making much sense to throw that into this again, at least at this time. I do have plenty of these that are close, and if you are making the column metal you can make them work, but not on a true 6. Sorry. Hi Mark, not quite true. The ones I received from you to try did fit on my -6, but they needed some alteration work to the bottom fixings points where the clam shell is screwed onto the steering column. The side holes were also slightly out so I decided to drill and tap new holes into the indicator and wiper housing. After searching the globe, I couldn't find any shells (well none that could be bought) so I had no other option, but the bottom line is that if someone a) has no other choice and b) has the time , tools and patience they WILL fit and when done, you'll never tell the difference. Despite the size issue, the rest of the casting and finish is excellent. See pics of some of the process. Chris. Attached thumbnail(s) |
Mikey914 |
Aug 27 2017, 03:21 PM
Thanks for the heads up. You wouldn't happen to have a template laying around would you?
mb911 |
Aug 27 2017, 04:27 PM
914forme |
Aug 27 2017, 07:37 PM
(IMG:style_emoticons/default/agree.gif) For my conversion car this will work just fine. For my real -6, I just hope the surround is not damaged. (IMG:style_emoticons/default/dry.gif)
But I would be in for one of these for the EG project car. |
Biggles |
Aug 28 2017, 03:29 AM
Thanks for the heads up. You wouldn't happen to have a template laying around would you? Yes I've still got the cardboard template. I could send it to you? It will also need drilling for the 2 main clam attachment points (can't remember the size?) and I also used 2 self tapper screws to attach the bracket onto the steering column. As mentioned, this isn't the end of it. Drilling and tapping the side holes will also need to be done by the installer. |
Mikey914 |
Aug 30 2017, 02:56 PM
I'm thinking about making the column with the "correct" fitment. That way the "conversion kit" would be complete. I have a sample, just need to modify and check fit.
Lo-Fi Version | Time is now: 29th May 2024 - 01:31 AM |
