Orphan Part, Where does it go and what does it do? |
jack20 |
May 25 2016, 06:56 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
TheCabinetmaker |
May 25 2016, 07:00 PM
Looks like the fuel pressure regulator bracket on the drivers side top tin, or, the thermo tine switch on the bottom passenger side of the plenum.
Gunn1 |
May 25 2016, 07:18 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Looks like the fuel pressure regulator bracket on the drivers side top tin, or, the thermo tine switch on the bottom passenger side of the plenum. Cabinetmaker, A little OT but do you still have the 2.0 liter TPS and runners available? I sent you a PM weeks ago and no reply back, must be using my controls incorrectly or something. Thank you! |
Mike D. |
May 25 2016, 07:24 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Look to be a broken off tab from the heater J tube. That is welded to the side and mounts to the engine tin.
jack20 |
May 25 2016, 09:03 PM
Wow! Would never have guessed that.
Thanks so much to you all. Jack |
Lo-Fi Version | Time is now: 17th May 2024 - 05:29 PM |
