Torque Rear Axle Nuts, Can this be done at home? |
jack20 |
May 25 2016, 08:53 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
When I removed the rear axle nuts I bolted a 3' length of angle iron onto the hub and placed it on a jack stand. I attached a socket on one end of a breaker bar and used a floor Jack on th other side to break it loose.
I don't have a torque wrench that breaks at the value called for in the Haynes book which I think is around 160ft#. I doubt that most of us garage guys have this tool. What do you all recommend for tightening the rear axle nuts. Thank You, Jack |
Keith914 |
May 26 2016, 11:46 AM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
I added an extension to the socket to clear the side of the car, then used a car jack stand to rest the extension on close to the center line of the wheel/axle, thus optimizing the bar, extension and socket leverage.
jack20 |
May 26 2016, 12:55 PM
I added an extension to the socket to clear the side of the car, then used a car jack stand to rest the extension on close to the center line of the wheel/axle, thus optimizing the bar, extension and socket leverage. Great suggestion. It worked perfectly. Here's the setup I used. Please no lectures about the lever style jack stands. I have others and always back up with floor jacks. ;-) |
Lo-Fi Version | Time is now: 25th May 2024 - 07:26 PM |
