Torque Rear Axle Nuts, Can this be done at home? |
jack20 |
May 25 2016, 08:53 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
When I removed the rear axle nuts I bolted a 3' length of angle iron onto the hub and placed it on a jack stand. I attached a socket on one end of a breaker bar and used a floor Jack on th other side to break it loose.
I don't have a torque wrench that breaks at the value called for in the Haynes book which I think is around 160ft#. I doubt that most of us garage guys have this tool. What do you all recommend for tightening the rear axle nuts. Thank You, Jack |
dangrouche |
May 28 2016, 10:50 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
If you are re-using the existing hub and nut, I dimple the hub and use a permanent maker to mark the nut with #1, #2, #3, #4, #5, & #6, prior to disassembly since you have to tighten the nut so the cotter pin will have to a clear hole. Also count the number of turns for removal of the nut. So when you reassemble, you know how many turns to tighten it in. YMMV, but this is ballpark guide if you don't want to buy a 300 ft. lb. torque wrench
mgp4591 |
May 30 2016, 09:32 AM
914 Guru Group: Members Posts: 5,377 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
If you are re-using the existing hub and nut, I dimple the hub and use a permanent maker to mark the nut with #1, #2, #3, #4, #5, & #6, prior to disassembly since you have to tighten the nut so the cotter pin will have to a clear hole. Also count the number of turns for removal of the nut. So when you reassemble, you know how many turns to tighten it in. YMMV, but this is ballpark guide if you don't want to buy a 300 ft. lb. torque wrench That's a great idea! At the dealership, we found that on an old Bug where the torque spec was also 250 ft lbs more or less that the axle nut castellation would be showing two threads past the axle cotter key hole. After many times doing this, we never had a problem with them coming loose or being overtightened. This method was also confirmed by the local VW aftermarket repair haus... they'd been doing it for more than 20 years with no issues. Of course, the usual disclaimers are to be taken into account and I assume no responsibility for injury or death resulting from this method... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 01:59 AM |
