Torque Rear Axle Nuts, Can this be done at home? |
jack20 |
May 25 2016, 08:53 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
When I removed the rear axle nuts I bolted a 3' length of angle iron onto the hub and placed it on a jack stand. I attached a socket on one end of a breaker bar and used a floor Jack on th other side to break it loose.
I don't have a torque wrench that breaks at the value called for in the Haynes book which I think is around 160ft#. I doubt that most of us garage guys have this tool. What do you all recommend for tightening the rear axle nuts. Thank You, Jack |
ThePaintedMan |
May 27 2016, 06:05 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Pfft.. the 911 GT3 Center locks get tightened to 420+ ft/lbs. Basically, if you come to the track and the locking "pin" isn't locked out, we send you away, back to find the nearest Porsche dealer to have them torque them and make sure they lock. Pissed off more than a few people on their Saturday mornings, but it's PCA regs.
ConeDodger |
May 27 2016, 10:46 PM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Pfft.. the 911 GT3 Center locks get tightened to 420+ ft/lbs. Basically, if you come to the track and the locking "pin" isn't locked out, we send you away, back to find the nearest Porsche dealer to have them torque them and make sure they lock. Pissed off more than a few people on their Saturday mornings, but it's PCA regs. George, I'm not saying the McLaren TW will not go to 420+ft/lbs. I'm saying it will do the torque spec for our cars... (IMG:style_emoticons/default/evilgrin.gif) |
ThePaintedMan |
Jun 1 2016, 09:15 PM
George, I'm not saying the McLaren TW will not go to 420+ft/lbs. I'm saying it will do the torque spec for our cars... (IMG:style_emoticons/default/evilgrin.gif) Sorry Rob, I realize now that post kinda came off "know it all"-ish. Yeah, either torque wrench would work. But 420 ft-lbs? Are you kidding me Porsche? On the original topic - again, my torque wrench only goes up to 150 ft lbs. So I take it up to 150, then I go to the next castellated nut position. Typically that's at least another 70 ft-lbs or so, which is right in spec. No way to be "perfect" on this one because of the castellated nut limitation. Just needs to be in the torque range provided. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:09 PM |
